[Gdal-dev] Re: gdal fails on vrt (virtual raster) file
Frank Warmerdam
warmerdam at pobox.com
Wed Sep 5 16:08:44 EDT 2007
WolfgangZ wrote:
> I will try tomorrow to convert these data on my linux machine (with
> FWTools) again. Furthermore I will try a "gdal_translate -of JPEG
> input.jpg out.jpg" on all tiles to get non progressive jpgs (hopefully).
> At least a more clear error would be nice to get a better hint where the
> error is. Would it also be possible to add to gdalinfo which compression
> is used (ie tiff has several possibilities (JPEG, LZW,...) and jpeg has
> a progressive and nonprogressive mode). I would suggest a --verbose mode
> for gdalinfo.
> Thanks for your help so far!
Wolfgang,
A lot of the error handling involved here is deep in libjpeg and so I think
it is hard for GDAL to provide detailed diagnostics.
It would be nice for the JPEG driver to indicate if a given file is
progressive or not. This could be returned as IMAGE_STRUCTURE domain
metadata and then it would be reported by gdalinfo. Patches welcome.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
