[Gdal-dev] Re: gdal fails on vrt (virtual raster) file
WolfgangZ
wollez at gmx.net
Fri Sep 7 01:48:22 EDT 2007
Even Rouault schrieb:
> Wolfgang,
> I'm not sure at all, but I have maybe an idea of what is going wrong.
> I ran recently into a similar problem with VRT made of several thousands of
> files, since when we open the VRT, we open each single dataset. This leads to
> a number of opened file descriptors > 1024 which is the usual limit for a
> Linux userland process. This has nothing to do with available RAM. The reason
> for it to work on Windows is that Windows has maybe a greater limit for
> opened files.
> Does "gdalinfo /sonstiges/GIS/Frankreich/Frankreich250k/20/39_20.jpg" work ?
> If it does, it may confirm my theory.
gdalinfo works well on single images!
> I've recently posted a patch in GDAL trac
> (http://trac.osgeo.org/gdal/ticket/1781) that fixed the issue on my big VRTs
> but it's probably too experimental/nasty to be applied in its current state.
> If you have the opportunity to build GDAL from subversion trunk, you could
> apply it and test if it improves the situation for you too.
perhaps next week I will find the time to try compiling on my own.
Regards
Wolfgang
