[Gdal-dev] problem to compile gdal 1.4.2 with kakadu JPG2000
support
Mateusz Loskot
mateusz at loskot.net
Fri Sep 7 10:35:22 EDT 2007
patrice canonici wrote:
> Hi Mateusz
> I solved the problem by compiling gdal with the configure option
> --without-libtool, and it is now a success.
Great!
> In fact I saw that gdal use its own libtool. I looked for version, and
> it was not the same as the one I have.
> so I tryed to execute the same command (/bin/sh
> /home/pcanonici/work/MapServer/gdal-1.4.2/libtool --mode=link
> g++ ogrinfo.o /home/pcanonici/w ..... ) with my libtool, and the
> result was the same.
> Note that I built kakadu following its documentation.
> Now I follow the link you give, i can see that :
> LIBTOOL support: no
> It seems to be very important to don't have libtool support activated.
> Can you tell me why ? I don't feel good with that.
I'm not sure why the libtools is a problem with Kakadu, but personally
I usually don't use libtool and build GDAL using --without-libtool
(mostly because it builds faster without libtool).
Is this a problem for you to not to use libtool when building
with Kakadu support?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
