[Gdal-dev] Reducing number of exported symbols
Even Rouault
even.rouault at mines-paris.org
Sun Sep 9 08:25:43 EDT 2007
Hello,
Pre-scriptum : it may be usefull to read http://gcc.gnu.org/wiki/Visibility to
understand some points of this discussion.
Reducing the number of symbols has a lot of benefits as stated in the above
link :
* speed up loading of shared objects
* better opportunities for code optimizations
* reduce the size of SO.
* much lower chance of symbol collisions.
I've looked at the number of exported symbols by libgdal.so. It reaches the
impressive number of 10 000 on my Linux system ! You can test on your own
system with : nm -C -D libgdal.so | wc -l
Then, I've grabbed FWTools136.exe and looked at gdal_fw.so. It "only" exports
3 549 symbols.
The reason is that on Windows, you have to explicitely declare that a symbol
is visible from outside the library. This is done in GDAL with the CPL_DLL
macro that expands to __declspec(dllexport) for MSC.
However with GCC, symbols are implicitely considered as public/exported unless
otherwise specified. Since GCC 4.0, we have a way to change that behaviour
through the -fvisibility=hidden flag. Thus we can define this flag and modify
the CPL_DLL declaration in cpl_port.h like hereafter to explicitely export
public symbols:
#ifndef CPL_DLL
#if defined(_MSC_VER) && !defined(CPL_DISABLE_DLL)
# define CPL_DLL __declspec(dllexport)
#else
# if defined(__GNUC__) && __GNUC__ >= 4
# define CPL_DLL __attribute__ ((visibility("default")))
# else
# define CPL_DLL
# endif
#endif
#endif
I give it a try on my system. This required only another change in shapefil.h
that doesn't use CPL_DLL but SHPAPI_CALL that is equivalent.
#ifndef SHPAPI_CALL
# define SHPAPI_CALL __attribute__ ((visibility("default")))
# define SHPAPI_CALL1(x) __attribute__ ((visibility("default"))) x
# else
# endif
#endif
Result : only 3 442 symbols ! Roughly like on Windows :-)
Another great benefit is that it should prevent subtle and annoying problems
when linking an executable with a GDAL library build with internal
libtiff/libpng/libjpeg/etc... and one of these libraries.Now most of them
have disappeared form libgdal.so. This may be becoming necessary with new
libtiff 4.0 that has become the internal GDAL libtiff, whereas most *nix
systems/distributios still uses 3.8.2. People will probably want to use
BigTIFF capabilities without messing up their system libtiff. Mixing symbols
from both versions is definitely not a good idea as there has been ABI
changes.
The case for internal libgeotiff is a bit different since it uses CPL_DLL too
in its header. So, symbols for internal libgeotiff are still exported. We
should fine a way to distinguish the case when it's built in GDAL tree from
when it's build standalone.
So, to sum up, if we want to integrate this in GDAL, we have to :
* change cpl_port.h and shapefil.h
* add a test for the support of -fvisibility=hidden in configure
Any thoughts on all of this ?
(I also tried to use -fvisibility-inlines-hidden but it fails on my system
since there's a bug in GCC 4.1 (apparently fixed in GCC 4.2). Anyway, it
should not make a large difference since GDAL code is not using lot of inline
functions.)
Best regards,
Even
