[Gdal-dev] Reading a World file for a Terragen .ter file
Brent Fraser bfraser at geoanalytic.com
Tue Sep 11 09:56:49 EDT 2007
Ray,
    I'll use one of the other drivers as guide, so it should
be consistent.
    Hmm I was going to see if I should update the on-line
doc on the GDAL formats page, but I see that the Terraingen
format is not listed (although there is a reference to
Terragen in the Leveler page).  Ray, if you do the write-up,
I'll be happy to edit it for my changes...
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
Cc: "gdal-dev" <gdal-dev at lists.maptools.org>
Sent: Monday, September 10, 2007 10:04 PM
Subject: Re: [Gdal-dev] Reading a World file for a Terragen
.ter file
> Assuming that's a standard approach, I can't fwiw see a
problem.
> You'd probably want to talk with Matt Fairclough,
Terragen's author, in
> case he's going to natively include georef data in the
next format revision.
> Ray
> Frank Warmerdam wrote:
> > Brent Fraser wrote:
> >> Frank, Ray G., (and other TerranGen driver users),
> >>   I'm considering enhancing the TerraGen driver to
include
> >> supporting the [optional] reading (and maybe the
writing) of
> >> a .wld/.trw file (since the TerraGen format itself does
not
> >> include the northing and easting offsets, just the
pixel
> >> scale).
> >> Any strong feelings one way or the other?  Other
thoughts?
> > Brent,
> > It sounds good to me.
> > Best regards,
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
