[Gdal-dev] Standard LICENSE / credit requirement reporting
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 13 11:26:34 EDT 2007
Folks,
I have implemented and committed the changes. GDAL should
now install LICENSE.TXT in /usr/local/share/gdal and it should
report it from the utilities if you give the --license switch
as well as from GDALVersionInfo().
I have also taken the liberty of modifying RFC 3 (commiter guidelines)
with this note in the legal section:
* Code with licenses requiring credit, or disclosure to users should be added
to /trunk/gdal/LICENSE.TXT.
While the practice of updating adopted RFCs is somewhat questionable,
I hope we can consider this a minor editorial change without having
a round of voting, etc. If there are any concerns let me know.
Best regards,
Even Rouault wrote:
> +1.
> GDALVersionInfo("LICENSE") is a good idea !
> On Wednesday 12 September 2007 03:40:34 Frank Warmerdam wrote:
>> Folks,
>> Also in the Provenance review effort, some licenses include clauses like:
>> * Redistributions in binary form must reproduce the above
>> copyright notice, this list of conditions and the following disclaimer
>> in the documentation and/or other materials provided with the
>> distribution.
>> which is sometimes referred to as a "credit requirement". Even the GDAL
>> license contains the text:
>> The above copyright notice and this permission notice shall be included
>> in all copies or substantial portions of the Software.
>> which has been read by some lawyers to imply the need to include the
>> license text in binary distributions of the software package.
>> In order to simplify reporting requirements for applications using GDAL and
>> for gdal utilities themselves, I propose to:
>> - add a LICENSE.TXT in the gdal source directly listing all licenses
>> and credit notices.
>> - install this file GDAL data files (/usr/local/share/gdal for instance)
>> - extend GDALVersionInfo("LICENSE") to report this file to stdout.
>> - add --license commandline switch to gdal and ogr standard commandline
>> processing to report this file.
>> In the future when we add code directly to GDAL with credit requirements
>> (or possibly when we depend on it as an optional library) we would add the
>> appropriate text in the gdal/LICENSE.TXT file.
>> Any thoughts on the appropriateness of this? Do we need an RFC for this?
>> It seems somewhat like overkill to me.
>> Best regards,
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
and watch the world go round - Rush | President OSGeo, http://osgeo.org
