[Gdal-dev] Fixing projections with GDAL_TRANSLATE vs. GDALWARP
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Sep 14 18:46:36 EDT 2007
Hi Rich,
> Yet it's odd that the very same specification of coordinate system, if
> given to gdal_warp via the -s_crs argument, works correctly. It's
> almost like the -s_crs argument works but -t_crs is not working, or
> else the Merc_1 info is being interpreted correctly when specified on
> the command linke, but written incorrectly written to or read from a
> GeoTIFF file.
To my understanding identical *_srs arguments should have identical
results across all of the gdal utilities. I tested this with your data
and without applying a spatial transform and the output is identical to
gdal_translate using -a_srs, save that some TIFFTAG metadata is stripped.
--- windows .bat ----
@echo off
:: warp vs trans
set inProj="+proj=merc +lat_ts=41.65 +lon_0=-70.3166667 +datum=nad83"
gdalwarp -s_srs %inProj% -t_srs %inProj% mb_backpc30m.tif merc-warp.tif
gdal_translate -a_srs %inProj% mb_backpc30m.tif merc-trans.tif
>> This bug is filed as http://trac.osgeo.org/gdal/ticket/1471 - gdalwarp
>> should keep georeferencing info
> According to my reasoning, I think this is not a problem of gdalwarp
> not keeping the georeferencing info. It could be a problem of not
> being able to correctly read/write merc 1_sp info into the geotiff
> correctly.
Hmm, yes, I guess that might be where the problem lies. I've been up and
down this so many times I don't know where I am anymore! Time to leave
it for now. :)
> P.S. Should this type of discussion take place here, or in trac ticket comments?
I don't really know. My inclination is to have discussion on the list
and distilled results to the ticket. It's the developers who use the
tickets the most, so I think they would have to weigh in to know which
is actually the most useful in practice.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
