[Gdal-dev] BigTiff and libtiff
Garrett Potts
potts at cfl.rr.com
Sun Sep 16 08:10:15 EDT 2007
Hello Frank:
I am just thinking of different Open SPEC ways that already exist
that we can take Video where each frame is tagged with a geospatial
component. So fast random access is not needed but sequential frame
per frame access could be. Most examples I am seen probably would
not exceed 1000 or so frames per day but didn't want a limit to hat
to exist on down the road.
Think of storing all frames and geospatial taggs ( orientation, frame
parameters, ... etc) per directory where eac h directgory is a single
frame. We can then have things like:
flight<data>.tif
to indicate a flight run on a single day. If we are capturing at
around 1 per second then this can get large.
Take care
Garrett
> I still can't fathom why anyone would want more than 64K
> directories in
> a TIFF chain, but if so, I don't see why the libtiff api couldn't
> be changed
> to use at least "int" for this in libtiff4.
> In any event, bug reports or patches should be reported via the
> libtiff
> bugzilla and further discussion ought to be on the tiff list.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://
> osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
