[Gdal-dev] Strange behaviour
Jose Luis Gomez Dans josegomez at gmx.net
Tue Sep 18 03:50:53 EDT 2007
I have found a problem with my python code when I reproject data using GDAL's python wrappers. For some reason, my SpatialReferences() get thrashed in some cases. I don't know where to start looking, but in my module, here are some results:
s =osr.SpatialReference()
s.ImportFromEPSG(23030)
s.ExportToWkt()
'PROJCS["ED50 / UTM zone 30N",GEOGCS["ED50",DATUM["European_Datum_1950",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","6230"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4230"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin","nan"],PARAMETER["central_meridian","nan"],PARAMETER["scale_factor",0],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","23030"]]'
s.ExportToProj4()
'+proj=tmerc +lat_0=nan +lon_0=nan +k=0,000000 +x_0=500000 +y_0=0 +ellps=intl +units=m +no_defs '
In a clean python instance, after importing osr, the results are as expected (i.e. non NaNs and stuff like that). I don't know where to start looking, whether this is locale, or file, or gdal version related (I'm using 1.4.1 on Linux/i386). The problem does not appear in Windows with an older version of GDAL.
Does anyone have any clues as to where to start looking for trouble?
Thanks!
Jose
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
