[Gdal-dev] Import Gdal
Howard Butler hobu.inc at gmail.com
Tue Sep 18 16:41:04 EDT 2007
On Sep 18, 2007, at 2:53 PM, Roger André wrote:
> Hi Gus,
> Did you install Python and GDAL separately?  In the past when I've
> installed GDAL independently, I've always had to specify that Python
> is present, and enable support within GDAL for it.  Here is a link to
> what appears to be a Windows executable that contains GDAL and Python
> 2.4 together - http://www.gdal.org/dl/win32/Python_GDAL-1.4.2.win32-
> py2.4.exe.
> Roger
Actually, that's just the Python binding.  You also need the "exe"
stuff too, which has the actual gdal dll.
Howard
> On 9/18/07, Gustavo Ces <g.ces at pettra.es> wrote:
>> Hi all,
>>     I´m newbie in Python so perhaps this problem is just a silly
>> one. I´ve
>> installed Python 2.4 and Gdal for this version ( executed de install
>> software). When i try to import gdal module the GUI writes:
>> Traceback (most recent call last):
>>   File "<pyshell#1>", line 1, in -toplevel-
>>     import gdal
>>   File "E:\Python24\Lib\site-packages\gdal.py", line 191,
>> in -toplevel-
>>     import _gdal
>> ImportError: DLL load failed: No se puede encontrar el módulo
>> especificado.
>> I don´t know what i have to do. Perhaps i had to do anything else.
>> Thanks in advance
>> Gus
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
