[Gdal-dev] Display help
Gauthier,Jean-Philippe [CMC]
Jean-Philippe.Gauthier at ec.gc.ca
Thu Sep 20 11:14:21 EDT 2007
If you are using OpenGL, just use the glPixelTrensferf functions to do the scaling and bias, something like that:
glEnable(GL_COLOR_TABLE);
glColorTable(GL_COLOR_TABLE,GL_RGBA,256,GL_RGBA,GL_UNSIGNED_BYTE,(GLvoid*)Band->Spec->Map->Color);
for (nc=0;nc<Band->Def->NC;nc++) {
switch(Band->Def->Type) {
case TD_UByte: Band->Tex.Scale[nc]=((0x1<<8)-1)/(Band->Spec->Map->Max[nc]-Band->Spec->Map->Min[nc]);
Band->Tex.Bias[nc]=-Band->Spec->Map->Min[nc]/((0x1<<8)-1);
break;
case TD_Byte: Band->Tex.Scale[nc]=((0x1<<7)-1)/(Band->Spec->Map->Max[nc]-Band->Spec->Map->Min[nc]);
Band->Tex.Bias[nc]=-Band->Spec->Map->Min[nc]/((0x1<<7)-1);
break;
case TD_UInt16: Band->Tex.Scale[nc]=((0x1<<16)-1)/(Band->Spec->Map->Max[nc]-Band->Spec->Map->Min[nc]);
Band->Tex.Bias[nc]=-Band->Spec->Map->Min[nc]/((0x1<<16)-1);
break;
case TD_Int16: Band->Tex.Scale[nc]=((0x1<<15)-1)/(Band->Spec->Map->Max[nc]-Band->Spec->Map->Min[nc]);
Band->Tex.Bias[nc]=-Band->Spec->Map->Min[nc]/((0x1<<15)-1);
break;
case TD_UInt32:
case TD_Int32:
case TD_Float32:
case TD_Float64: Band->Tex.Scale[nc]=1.0/(Band->Spec->Map->Max[nc]-Band->Spec->Map->Min[nc]);
Band->Tex.Bias[nc]=-Band->Spec->Map->Min[nc];
break;
glPixelTransferf(sc[nc],Band->Tex.Scale[nc]);
glPixelTransferf(bc[nc],Band->Tex.Bias[nc]*Band->Tex.Scale[nc]);
Jean-Philippe Gauthier Bilodeau Direction des opérations
Analyste Programmeur Scientifique Centre Météorologique Canadien
Tel : (514) 421-4642 2121 Route Transcanadienne
Fax: (514) 421-4679 Dorval,Québec
Email: Jean-Philippe.Gauthier at ec.gc.ca H9P 1J3
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: 20 September, 2007 11:49
To: Christiaan Janssen
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Display help
Christiaan Janssen wrote:
> Could anyone give me some suggestions on what would be the appropriate
> method for displaying raster data with GDAL. I'm currently using
> openGL which is all fine but I have an issue dealing with imagery
> thats over 8 bit. Is there a way to have GDAL scale the sample values
> or is this something I would have to do manually. Thanks
Christiaan,
Generally speaking I'd suggest you rescale the data as a post processing step after reading it with GDALRasterIO(). There are GDAL calls to get min/max and stats information that may be helpful to you in deciding on a scaling strategy.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
