[Gdal-dev] Affine Transformation and Calibration Equation for
Maptech/BSB format
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 27 10:46:41 EDT 2007
On 9/27/07, marcello ferrero <marcello_ferrero at yahoo.com> wrote:
> I believe the parameters for a more precise transformation are already in
> the BSB header in the WBX,WPY and PWX, PWY fields,
> but I'm not sure what are the correct data to use.
> For example if we consider the chart file 11013_1.KAP (STRAITS OF
> FLORIDA AND APPROACHES)
> the following values are in the header.
> WPX/3,74057.63283,914.1573321,-4.457688988e-006,0.9314526304,4.199727384e-007
> 8.909433511e-007,0.003888412047,4.049230257e-009,4.656999088e-009
> -7.344637416e-009
> WPY/3,24849.77398,-0.0001719938458,-841.3888082,-2.236403169e-006
> -4.23802978e-007,0.5645817982,-9.615822208e-009,-2.118680351e-009
> 1.85245272e-009,-0.05788953807
> PWX/3,-85.82846924,0.001190193579,1.242062009e-015,1.177436646e-010
> 4.828087799e-020,-4.158931771e-019,-7.813843316e-015,-1.938704561e-024
> -3.205324874e-024,3.339741723e-023
> PWY/3,28.48799091,4.631711681e-016,-0.001052175742,-7.983285528e-020
> -7.030373462e-020,-5.245662991e-009,4.239300639e-024,1.848231681e-024
> What are the parameters between them to take into account?
> Also, what kind of trasformation is this one? Is it a sort of calibration
> equations that uses also the ref points and errors contained in the same BSB
> file?
Marcello,
I do not know for sure, but I presume these parameters are for
at least a 2nd order polynomial. I have made only a very
minor effort to deduce these details but was not successful.
Internally GDAL can compute 2nd order polynomial warp
equations from the reference points and this is what I
generally encourage people to use (via gdalwarp) to
convert the images to a nice "north up" image. But, in
fact, I presume the files are actually normally in a mercator
projection and that we would be even better off to work out
the details of that and then use proper reprojection to get
to other coordinate systems.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
