[Gdal-dev] Ogr and Postgis support
Lucian Canacheu lcanacheu at zappmobile.ro
Sat Sep 29 06:41:29 EDT 2007
Hi Gus,
In short, no. PostGIS support is disabled by default and if you user the
binary distro fromgdal.org, that it is a "minimalist" build. Whatever
Python bindings you add to it you won't get PostGIS support - it is not
"enabled" in that distribution.
I passed over your messages. I'm using Python bindings for GDAL/OGR/OSR
with PostGIS and  a couple of years  ago (I think with version 1.3.0 or
so) I had very  tough times trying to install GDAL binaries into a
Python "clean" environment. I've tried lots of things and in my opinion
it was not the right way to do it. So, it may sound scary, you have to
build yourself most of the needed libraries from sources (in this order)
- proj4.5, libecw3.3, install Postgresql and PostGIS, geos2.2.3. The
GDAL compilation works flawlessly on Win32 with VS 2003 and on Linux
with compiler gcc 3.4.6.
I used these setup procedures ever since GDAL v 1.3.x. Give it a try and
you'll see it works.
If you work this way, you'll have the chance to enable PostGIS
extensions on Win32 platform. These are disabled by default:
# PostGIS Libraries
#PG_INC_DIR = n:\pkg\libpq_win32\include
#PG_LIB = n:\pkg\libpq_win32\lib\libpqdll.lib wsock32.lib
in the nmake.opt file
On Linux, you have to do something like this:
./configure --with-python=/opt/python-2.4.4/bin/python
--with-postgres-includes=/usr/include/pgsql
--with-postgres-libraries=/usr/lib
in order to enable PostGIS.
Cheers,
Lucian
Lucian Canacheu
Glipco Srl Deva
IT/GIS/Tech
Mobile: +40 788 503 385
E-mail: lcanacheu at glipco.ro
Gustavo Ces wrote:
> Hi all,
>     I�ve posted a few weeks ago about gdal installing in a python 2.4
> "clean" version. I�ve achieved to install
> python, gdal ( win bin & python bindings ), and other stuff ( with
> your help). But now i�ve got a problem. I can connect to Posgis with
> pygresql, but i can�t do the same with gdal. Running 'ogrinfo
> --formats', there isn�t a postgis one. So i supose there isn�t support
> in Gdal�s ogr distribution for this DBMS. Maybe i�m wrog. Any help?
>     Thanks in advance,
> Gus
> __________ NOD32 2556 (20070928) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.eset.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
> http://www.eset.com
Lucian Canacheu
Glipco Srl Deva
IT/GIS/Tech
