[gdal-dev] OGR Feature Style Specification
Tamas Szekeres
szekerest at gmail.com
Thu Apr 17 09:22:59 EDT 2008
2008/4/17, Ari Jolma <ari.jolma at tkk.fi>:
> Since SVG is a pretty general it should be able to handle all styles and
> mapping to it is then just a technical problem?
I don't know
> > 5. How about the compatibility issues with the existing applications?
> > Would it be easy to migrate their existing scripts. For example if the
> > application use the WHERE OGR_STYLE LIKE 'BRUSH' according to
> > http://www.gdal.org/rfc6_sqlgeom.html ?
> That kind of statement assumes quite much and I'm not sure if such
> constraints should be encouraged. There is no "brush" in SVG styles AFAIK.
> Maybe SVG styles should be implemented as a "new styles" and deprecate the
> old styles eventually?
One of the use cases I'm aware of is when a mapinfo layer contains
features with different styles and we would like to distinguish
between those features. For example if I want to select all of the
labels from that layer and represent the labels as a separate layer in
mapserver.
> > Further issues:
> > 6. Can we support the dataset/layer level default styles as described
> > in the OGR Feature Style specification but haven't been implemented
> > yet?
> Isn't that the matter of just adding a style member into the dataset/layer
> class? Do features have knowledge of the layer they belong to? Then they can
> return the default style if they do not have a style of their own.
The features don't have back references to their layers at the moment.
Tamas
