[gdal-dev] gdal_rasterize does not burn the polygon]
Frank Warmerdam
warmerdam at pobox.com
Sun Apr 20 10:10:05 EDT 2008
Xiaodong Zhang wrote:
> Hi there,
> I tried to use "gdal_rasterize -burn 0 -l test test/test.shp
> 2003_Yield_03.tif" to highlight the area covered by the polygon, but it
> does not seem to work. The figure below shows the polygon is inside the
> extension of the image. The problem is that the area inside the polygon
> was not highlighted (or burned). Could anybody please tell me where I
> did wrong. The test data is attached.
> The image and the shape file are not in the same projection, but I'm not
> sure if this could be the cause. As both of them showed nicely in ENVI.
> I used ogr2ogr to convert a few points into a polygon using WKT format.
> Do I need to some fancier thing to make polygons?
Xiaodong,
The problem is indeed the incompatible coordinate systems. I copied
the gdalinfo report of the .tif projection to a file called target.prj
(these contents):
PROJCS[" Projection Name = Lambert Azimuthal Equal-ar",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Then reprojected the vectors like this:
ogr2ogr out.shp test -t_srs ./target.prj
Then did the rasterize:
gdal_rasterize -burn 0 -l out out.shp 2003_Yield_03.tif
And the expected effect was achieved.
The lesson is that gdal_rasterize will not reproject your vector
input for you. You need to do this yourself. If you wish you could
file a ticket requesting that gdal_rasterize be improved, or at least
issue a warning in a case like this.
In the meantime, reproject your inputs manually.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
