[Gdal-dev] Change EXTENT of a shapefile
Frank Warmerdam
warmerdam at pobox.com
Mon Apr 21 09:46:29 EDT 2008
shortyII wrote:
> Hi,
> i am trying to change the EXTENT parameters of a shapefile with ogr2ogr:
> ogr2ogr -update -spat 3500000 5300000 3540000 5400000 rastervorlage.shp
> rastervorlage.shp
> FAILED: Layer rastervorlage already exists, and -append not specified.
> Consider using -append, or -overwrite.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer rastervorlage
> but it doesn't work. (-append and -overwrite also don't work)
> Is it in principal possible to change the extent and how can i do it?
> Thank you!
Stefan,
You cannot subset the features within a shapefile with ogr2ogr, you need
to copy the subset to a new shapefile.
So instead use:
ogr2ogr -spat 3500000 5300000 3540000 5400000 out.shp rastervorlage.shp
Once complete you can delete the original, and rename the new to the
original if you want.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
