[gdal-dev] gdal1.5.1 make error on RedHat Linux
Gong, Shawn (Contractor)
Shawn.Gong at drdc-rddc.gc.ca
Tue Apr 22 12:16:18 EDT 2008
hi list,
I got make errors on gdalhttp.cpp:209. The following is the last part of
the make log.
Platform: RedHat Enterprise Linux version 4, and gcc compiler version
3.2.3.
Any help is appreciated.
thanks,
Shawn
make[2]: Entering directory `/home/sgong/dev18/gdal-1.5.1/frmts/adrg'
/bin/sh /home/sgong/dev18/gdal-1.5.1/libtool --mode=compile --tag=CXX
g++ -g -O2 -Wall -I/home/sgong/dev18/gdal-1.5.1/port
-I/home/sgong/dev18/gdal-1.5.1/gcore -I/home/sgong/dev18/gdal-1.5.1/alg
-I/home/sgong/dev18/gdal-1.5.1/ogr
-I/home/sgong/dev18/gdal-1.5.1/ogr/ogrsf_frmts -DOGR_ENABLED
-I/home/sgong/dev18/gdal-1.5.1/port -I/home/sgong/dev18/dist
-I/home/sgong/dev18/dist/include -I../iso8211 -c -o ../o/adrgdataset.o
adrgdataset.cpp
libtool: compile: g++ -g -O2 -Wall -I/home/sgong/dev18/gdal-1.5.1/port
-I/home/sgong/dev18/dist/include -I../iso8211 -c adrgdataset.cpp -fPIC
-DPIC -o ../o/.libs/adrgdataset.o
-I/home/sgong/dev18/dist/include -I../iso8211 -c adrgdataset.cpp -o
../o/adrgdataset.o >/dev/null 2>&1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/adrg'
make -C coasp install-obj
make[2]: Entering directory `/home/sgong/dev18/gdal-1.5.1/frmts/coasp'
-I/home/sgong/dev18/dist/include -c -o ../o/coasp_dataset.o
coasp_dataset.cpp
-I/home/sgong/dev18/dist/include -c coasp_dataset.cpp -fPIC -DPIC -o
../o/.libs/coasp_dataset.o
-I/home/sgong/dev18/dist/include -c coasp_dataset.cpp -o
../o/coasp_dataset.o >/dev/null 2>&1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/coasp'
make -C tsx install-obj
make[2]: Entering directory `/home/sgong/dev18/gdal-1.5.1/frmts/tsx'
-I/home/sgong/dev18/dist/include -c -o ../o/tsxdataset.o tsxdataset.cpp
-I/home/sgong/dev18/dist/include -c tsxdataset.cpp -fPIC -DPIC -o
../o/.libs/tsxdataset.o
-I/home/sgong/dev18/dist/include -c tsxdataset.cpp -o ../o/tsxdataset.o
>/dev/null 2>&1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/tsx'
make -C terragen install-obj
`/home/sgong/dev18/gdal-1.5.1/frmts/terragen'
-I/home/sgong/dev18/dist/include -c -o ../o/terragendataset.o
terragendataset.cpp
-I/home/sgong/dev18/dist/include -c terragendataset.cpp -fPIC -DPIC -o
../o/.libs/terragendataset.o
terragendataset.cpp: In member function `bool
TerragenDataset::write_header()':
terragendataset.cpp:626: warning: `int bh' might be used uninitialized
in this
function
-I/home/sgong/dev18/dist/include -c terragendataset.cpp -o
../o/terragendataset.o >/dev/null 2>&1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/terragen'
make -C wcs install-obj
make[2]: Entering directory `/home/sgong/dev18/gdal-1.5.1/frmts/wcs'
-I/home/sgong/dev18/dist/include -c -o ../o/wcsdataset.o
wcsdataset.cpp
-I/home/sgong/dev18/dist/include -c wcsdataset.cpp -fPIC -DPIC -o
../o/.libs/wcsdataset.o
-I/home/sgong/dev18/dist/include -c wcsdataset.cpp -o ../o/wcsdataset.o
>/dev/null 2>&1
-I/home/sgong/dev18/dist/include -c -o ../o/httpdriver.o
httpdriver.cpp
-I/home/sgong/dev18/dist/include -c httpdriver.cpp -fPIC -DPIC -o
../o/.libs/httpdriver.o
-I/home/sgong/dev18/dist/include -c httpdriver.cpp -o ../o/httpdriver.o
>/dev/null 2>&1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/wcs'
make -C wms install-obj
make[2]: Entering directory `/home/sgong/dev18/gdal-1.5.1/frmts/wms'
-I/home/sgong/dev18/dist/include -c -o ../o/cache.o cache.cpp
-I/home/sgong/dev18/dist/include -c cache.cpp -fPIC -DPIC -o
../o/.libs/cache.o
-I/home/sgong/dev18/dist/include -c cache.cpp -o ../o/cache.o >/dev/null
2>&1
-I/home/sgong/dev18/dist/include -c -o ../o/dataset.o dataset.cpp
-I/home/sgong/dev18/dist/include -c dataset.cpp -fPIC -DPIC -o
../o/.libs/dataset.o
-I/home/sgong/dev18/dist/include -c dataset.cpp -o ../o/dataset.o
>/dev/null 2>&1
-I/home/sgong/dev18/dist/include -c -o ../o/gdalhttp.o gdalhttp.cpp
-I/home/sgong/dev18/dist/include -c gdalhttp.cpp -fPIC -DPIC -o
../o/.libs/gdalhttp.o
gdalhttp.cpp: In function `CPLErr CPLHTTPFetchMulti(CPLHTTPRequest*,
int, const
char* const*)':
gdalhttp.cpp:209: `CURLINFO_RESPONSE_CODE' undeclared (first use this
function)
gdalhttp.cpp:209: (Each undeclared identifier is reported only once for
each
function it appears in.)
make[2]: *** [../o/gdalhttp.o] Error 1
make[2]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts/wms'
make[1]: *** [wms-install-obj] Error 2
make[1]: Leaving directory `/home/sgong/dev18/gdal-1.5.1/frmts'
make: *** [frmts-target] Error 2
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080422/794d8e95/attachment-0001.html
