[gdal-dev] Problem getting projection info from NetCDF
Matt Foster Matthew.Foster at noaa.gov
Wed Apr 23 12:21:03 EDT 2008
My apologies if this shows up twice...
Somewhere between version 1.3.0 and 1.5.1 something changed in gdal such
that I can no longer get the projection info from some NetCDF datasets
that I have.  I believe my data are CF-compliant, so I'm having trouble
figuring out what gdal doesn't like.
I can supply the NetCDF header info, if that would help...or perhaps
someone will know something that became more 'strict' in gdal.
TIA
Matt
The cosmos is all that is or ever was or ever will be.
-- Carl Sagan
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080423/a90ff8be/matthew_foster.vcf
