[gdal-dev] Re: reprojecting a georeferenced image (PNG, JPG)
Christian Müller
christian.mueller at nvoe.at
Mon Aug 4 09:39:55 EDT 2008
run the program with:
gdlawarp-co "WORLDFILE=YES" ....
Tim Michelsen writes:
> Hello,
> I have a PNG file with some transparent areas.
> I used QGIS to georeference the file using the latlon/WGS84 projection settings.
> Within this process, a world file (*.wld) and a point file where created.
> Now, I'd like to reproject this image into another projection.
> How do I have run gadlwarp that:
> * the transparen regions in the PNG are being maintained tranparent and
> * a new word file is written which corresponds to the new projection settings?
> I tried to run the program with "-worldfile=yes" but no new worlfile was written.
> Thanks in advance,
> Timmie
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
