[gdal-dev] OGR2OGR - Define output naming from concatenated
queries from a DB
Mateusz Loskot
mateusz at loskot.net
Thu Aug 7 11:51:02 EDT 2008
D wrote:
> Hi Mateusz,
> thanks for the help and the sample! I will try to implement it. I have also
> received a sample from an Oracle DBA how to create a Batch file with a
> properly defined command line while executing an SQL script with some PL/SQL
> procedures.
Dejan,
Sounds good.
> If interested, I will send it to you, when completed developing and testing
> it.
IMO, mailing list (ie. as reply to this thread) is better place, so
others can use it as well.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
