[gdal-dev] Problem importing osgeo module in Python
Roger André
randre at gmail.com
Fri Aug 8 19:15:13 EDT 2008
Hi Chris,
> that shouldn't be required -- site-packages should be on your sys.path
> already. Is your python in /export/lib64/python2.3 ? Do you have more than
> one python?
My Python is not in /export/lib64/python2.3. (for some reason, saying that
makes me laugh, but I digress) I also do not have more than one version
installed.
try:
> $ python
> >> import datetime 3 or any standard module
> >> print datetime.__file__
That's a useful trick, thanks. My python install appears to be in:
/usr/lib64/python2.3
> Also -- why python 2.3? that's getting pretty darn old!
Yeah, defintely. This is a work machine, and I'm going to have to get onto
my soapbox to get IT to up the version in our production environment as
well.
Thanks for the help. I did get this working by adding the gdal lib path to
ld.so.conf and running ldconfig. Then added a PYTHONPATH setting in .bashrc
that points to the /export/lib64/site-package dir.
Roger
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R (206) 526-6959 voice
> 7600 Sand Point Way NE (206) 526-6329 fax
> Seattle, WA 98115 (206) 526-6317 main reception
> Chris.Barker at noaa.gov
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080808/2e674219/attachment.html
