[gdal-dev] Problem importing osgeo module in Python
Roger André
randre at gmail.com
Fri Aug 8 19:44:31 EDT 2008
No, no, there is nothing wrong with the install scripts. The reason it
placed the stuff there is because I specified a --prefix=/export flag in my
configure command. I installed a bunch of different things on my machine,
and I have a large mounted disk at /export.
Thanks for the follow-up though.
On Fri, Aug 8, 2008 at 4:39 PM, Christopher Barker <Chris.Barker at noaa.gov>wrote:
> Christopher Barker wrote:
>> What is /export? I've seen that before.
> I meant, I HAVEN'T seen that before.
> Anyone, what I'm trying to figure out is if there is something wrong with
> GDAL's install scripts, or if there is something odd about your system.
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R (206) 526-6959 voice
> 7600 Sand Point Way NE (206) 526-6329 fax
> Seattle, WA 98115 (206) 526-6317 main reception
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080808/b27d21e8/attachment.html
