[gdal-dev] Update ShapeLayer
Mateusz Loskot mateusz at loskot.net
Sun Aug 10 08:35:24 EDT 2008
wow wrote:
> Hi,
>   To update shape files. i got two questions:
wow,
For Shapefile updating issues, read this post:
http://lists.osgeo.org/pipermail/gdal-dev/2008-August/017855.html
>  1. How could i delete a field from a shapelayer?
You have to create new Shapefile based on attributes schema of the
exisiting Shapefile but removing unwanted field.
If your shapefile stores any features, it's not possible to update its
structure.
>  2. How to set a value to a specified field of all records?
 > Could i use SQL sentences like "set field_name='value'" on the
> datasource of shapelayer?
You can do it programmatically with a script or C/C++ program.
OGR SQL [1] engine does not support SQL UPDATE/INSERT commands.
[1] http://gdal.org/ogr/ogr_sql.html
BTW, it's a good idea to scan the archives of this mailing list, where
you will find a lot of discussion about updating Shapefile issues.
Best regards
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
