[gdal-dev] curve fit question
Clay, Bruce bclay at ball.com
Mon Aug 11 12:46:56 EDT 2008
Does anyone know of a function in GDAL or related libraries that given a
set of points it will return a new set of points that is or can be used
to create a smoothed polyline?  I have heard about things like linear
fit and least squares but I have not used them and I am quite rusty on
the math used to calculate a smoothed line from a set of points.  I have
done a lot of web searching and found various generic algorithms but I
don't see how to apply them.  For example a linear regression sample
takes in a set of X-Y points but it only returns 3 values of C and
standard deviation.
Any help would be greatly appreciated.
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080811/5037315b/attachment.html
