[gdal-dev] could GDAL enforce towgs84=0,0,0 for ETRS89-based CRSs?
Maciej Sieczka
tutey at o2.pl
Wed Aug 13 15:57:33 EDT 2008
Another interesting thing: reprojecting rasters using an EPSG code of an
ETRS89 based CRS, results in a GeoTIFF header lacking the latlong
boundaries (the last 5 lines of gdalinfo output below):
$ gdalwarp -t_srs EPSG:3035 N51E016.hgt srtm_etrs89.tif
$ gdalinfo srtm_etrs89.tif
Driver: GTiff/GeoTIFF
Files: srtm_etrs89.tif
Size is 1023, 1516
Coordinate System is:
PROJCS["ETRS89 / ETRS-LAEA",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4258"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3035"]]
Origin = (4732497.919957611709833,3233119.219332384876907)
Pixel Size = (77.290356972219669,-77.290356972219669)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 4732497.920, 3233119.219)
Lower Left ( 4732497.920, 3115947.038)
Upper Right ( 4811565.955, 3233119.219)
Lower Right ( 4811565.955, 3115947.038)
Center ( 4772031.938, 3174533.129)
Band 1 Block=1023x4 Type=Int16, ColorInterp=Gray
Whereas the same raster reprojected to e.g. a Pulkovo 1942(58) based CRS
has these latlon coordinates in place:
$ gdalwarp -t_srs EPSG:2174 N51E016.hgt srtm_pulkovo.tif
$ gdalinfo srtm_pulkovo.tif
Files: srtm_pulkovo.tif
Size is 909, 1444
PROJCS["Pulkovo 1942(58) / Poland zone IV",
GEOGCS["Pulkovo 1942(58)",
DATUM["Pulkovo_1942_58",
SPHEROID["Krassowsky 1940",6378245,298.2999999999985,
AUTHORITY["EPSG","7024"]],
AUTHORITY["EPSG","6179"]],
AUTHORITY["EPSG","4179"]],
PROJECTION["Oblique_Stereographic"],
PARAMETER["latitude_of_origin",51.67083333333333],
PARAMETER["central_meridian",16.67222222222222],
PARAMETER["scale_factor",0.9998],
PARAMETER["false_easting",3703000],
PARAMETER["false_northing",5627000],
UNIT["metre",1,
AUTHORITY["EPSG","2174"]]
Origin = (3655914.793169156182557,5663915.491245908662677)
Pixel Size = (77.265039270892487,-77.265039270892487)
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 3655914.793, 5663915.491) ( 15d59'11.37"E, 52d 0'2.46"N)
Lower Left ( 3655914.793, 5552344.775) ( 16d 0'5.03"E, 50d59'51.91"N)
Upper Right ( 3726148.714, 5663915.491) ( 17d 0'33.70"E, 52d 0'7.90"N)
Lower Right ( 3726148.714, 5552344.775) ( 17d 0'7.31"E, 50d59'57.19"N)
Center ( 3691031.754, 5608130.133) ( 16d29'59.40"E, 51d30'3.86"N)
Band 1 Block=909x4 Type=Int16, ColorInterp=Gray
Why the difference?
Maciek
Maciej Sieczka
www.sieczka.org
