[Gdal-dev] Tif file getting larger and larger
Fodder
cryan at csse.com.au
Thu Aug 14 02:00:03 EDT 2008
I have a program that is reading and writing to a GeoTif file using Open,
RasterIO and Close calls and Float32 data types.
However, I find that the file just gets larger and larger whenever I write
to the file even though I'm trying to overwrite the existing data. For
example, if open a Tif file with a large range of values and then write the
same value to every pixel and close the dataset, I don't see any reduction
in file size as I would expect to result from the compression. I've noticed
this with LZW and Packbits compression, tiled and striped.
I'm sure it's something simple I'm missing.
Cheers,
View this message in context: http://www.nabble.com/Tif-file-getting-larger-and-larger-tp18976082p18976082.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
