[gdal-dev] OGR Translate File
Gregor Mosheh
gregor at hostgis.com
Thu Aug 14 17:59:08 EDT 2008
Mateusz Loskot wrote:
> If you are going to use php_ogr, I recommend to
> read the thread "gdal-dev] Future of PHP bindings"
In that discussion, they mention the same download as I commonly use,
and enjoy. http://dl.maptools.org/dl/php_ogr/ Works great.
Are you saying that THAT php_ogr will also be orphaned, and/or that GDAL
will change to be incompatible with it?
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
