[gdal-dev] deleting feature exceptions
=?gbk?B?d293?= 27949218 at qq.com
Thu Aug 14 21:56:20 EDT 2008
    i try to delete features from a set of shape file, sometimes get error. I use this version of ogrshapelayer.cpp  : http://trac.osgeo.org/gdal/changeset/10969 . Delete feature in two ways would get different result:
 (1)  for(iFeat=0;iFeat<nFeat;iFeat++)
        int cplE = pLayer->DeleteFeature(0);
        if(cplE==CE_None)
         OGRShapeLayer* pShpLayer = (OGRShapeLayer*)pLayer;
         cplE = pShpLayer->Repack();
          if(cplE!=CE_None)
            printf("delete feature failed £¡\n");
            return false;
    int nFeatRest = pLayer->GetFeatureCount();
     These codes could delete each feature with returned value CE_None, and  at the end nFeatRest=0. But when ran to pShpLayer->Repack()  second, the error occurs: "Failure writing DBF record 0", it jumped untill all features were deleted.
 (2)  for(iFeat=nFeat-1;iFeat>=0;iFeat--)
      int cplE = pLayer->DeleteFeature(iFeat);
      if(cplE==CE_None)
           if(cplE!=CE_None)
          return false;
     These codes could delete each feature with returned value CE_None, but at the end nFeatRest>0 and nFeatRest<nFeat, some features were NOT deleted yet!   Same as (1), when ran to pShpLayer->Repack()  second, the error occurs: "Failure writing DBF record iFeat", it jumped untill all features were deleted.
     Trace the error  "Failure writing DBF record ..." into Repack():
   /*      Build a list of records to be dropped.                          */
     for( iShape = 0; iShape < nTotalShapeCount; iShape++ )
        if( DBFIsRecordDeleted( hDBF, iShape ) )//------------ERROR jumped ---------
            panRecordsToDelete[nDeleteCount++] = iShape;
    Why did this phenomena occurs?
     Thank you.
  To the world you're little, but to a person you're the world.
                                             Chen Xuexia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080815/2c555853/attachment-0001.html
