[gdal-dev] Guidance sought on using gdal-translate
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 18 10:50:17 EDT 2008
On 8/16/08, Christopher Hunt <huntc at internode.on.net> wrote:
> Hopefully one last question on this though: the a_ullr parameters - given
> the a_srs spec of EPSG:27700, are the a_ullr parameters expected to be in
> BNG coordinates i.e. eastings and northings values? Asking this another way,
> what actually dictates the coordinate system used for the a_ullr parameters?
Chris,
The coordinates in the -a_ullr should match the coordinate
system of the image (ie. what gdalinfo reports for instance)
or the coordinate system supplied in -a_srs if you give that
to assign a new coordinate system.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
