[gdal-dev] OGRFeatureStyle update from version1.4.1 to 1.5.2;
wow 27949218 at qq.com
Mon Aug 18 21:33:14 EDT 2008
Frank, this is my example for you to test the ver1.5.2 OGRFeatureStyle.cpp. Thank you.
 //-------------------------------CODE----------------------------------------------------------
     bool CreateDefaultStyle("shpcreate\\1.tbl", 2);
     void main()
    bool res = CreateDefaultStyle("shpcreate\\1.tbl", 2);
 bool CreateDefaultStyle(CString strTlbPath, int nType)
      OGRStyleTable oStyleTable;
      OGRStyleMgr   *poStyleMgr = new OGRStyleMgr(&oStyleTable);
      bool res;
      switch(nType)
          case 1:            //point
            res = poStyleMgr->AddStyle("@symbol", "SYMBOL(c:#00FF00,id:\"swS0\",s:1.0,l:1)");
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#FFFF00,f:\"MS Gothic\",s:10px,t:\"\",l:1)");
            res = oStyleTable.SaveStyleTable(strTlbPath);
           break;
         case 2:              //line
            res = poStyleMgr->AddStyle("@symbol", "SYMBOL(c:#00FF00,id:\"swS0\",s:1.0,l:1)");//
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#0000FF,f:\"MS Gothic\",s:10px,t:\"\",l:1)");//
            res = poStyleMgr->AddStyle("@line", "PEN(c:#FF0000,w:3px,id:\"swL0\",l:1)");//
           break;
        case 3:              //polygon
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#FF0000,f:\"MS Gothic\",s:10px,t:\"\",l:1)");
            res = poStyleMgr->AddStyle("@brush", "BRUSH(fc:#C0C0C0,id:\"swR0\")");
           break;
      default:
           break;
   if(poStyleMgr)
     delete poStyleMgr;
     poStyleMgr = NULL;
  if(!res)
     return false;
  return true;
 //--------------------------------END----------------------------------------------------------
  To the world you're little, but to a person you're the world.
                                             Chen Xuexia
 ------------------ Original ------------------
 Date:  Tue, Aug 19, 2008 09:13 AM
 To:  "Frank Warmerdam"<warmerdam at pobox.com>;
 Cc:  "gdal-dev"<gdal-dev at lists.osgeo.org>;
 Subject:  Re: [gdal-dev] OGRFeatureStyle update from version1.4.1 to 1.5.2;
  Hi,  Frank, welcome to China. I'd like to see you in Beijing, i'm sure that you're the  joss of many young students, hehe.
   I have found the reason why  failed to deal styles with ver1.5.2. Compared  with ver1.4.1,   CPLSPrintf() is replaced the CPLString().Printf()  , and i could trace the error to CPLString().Printf() every time debug. It might not allocate memory for the dest string in CPLString().Printf(). Of cource, if i still use CPLSPrintf(), no error occurs. Is this a bug in whole OGRFeatureStyle.cpp in ver1.5.2?
                                             Chen Xuexia
 Date:  Mon, Aug 18, 2008 11:12 PM
 To:  "wow"<27949218 at qq.com>;
 On 8/17/08, wow <27949218 at qq.com> wrote:
> Hi,
>   When i tried to update my whole program from ver1.4.1 to 1.5.2, all worked
> well except the  OGRFeatureStyle  module. The function
> OGRStyleMgr::AddStyle() couldn't write the provided style
> name and style string right with ver1.5.2, but could run smoothly with
> version 1.4.1.
>   My code :
Chen,
There has been some work on the style string parser since 1.4 and
I suspect it has been subtly broken for your case in some fashion.
Could you file a ticket?  Make sure you provide any additional
details we might need, like the format you are trying to write to.
Ideally a single small self contained program demonstrating the
problem would be best.
Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080819/3aa10c22/attachment-0001.html
