[gdal-dev] GSoC GDAL2Tiles: MapTiler.org,
Google Maps Projection Web, Source Code
Klokan Petr Přidal
klokan at klokan.cz
Tue Aug 19 02:55:44 EDT 2008
Hi Craig,
For clipping you should use another GDAL tools before passing raster
to gdal2tiles for tile generation.
If you need to clip just by specifying bounding box in source
coordinates or raster coordinates you can use 'gdal_translate' on the
input raster and its parameters -srcwin or -projwin (probably with -of
VRT).
If you have shapefile of the mask, then use tool like 'gdal_rasterize'
to burn the mask into the alpha channel band.
Best regards
Klokan
On Mon, Aug 18, 2008 at 11:30 PM, Craig Miller
<craig.miller at spatialminds.com> wrote:
> Nice work. Looks great.
> Can a bounding box for the input image be specified so the collar will be trimmed prior to creating the tile images?
> Craig
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Guillaume Sueur
> Sent: Monday, August 18, 2008 2:07 PM
> To: Klokan Petr Přidal
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GSoC GDAL2Tiles: MapTiler.org, Google Maps Projection Web, Source Code
> That's an awesome job actually Klokan ! Thanks for these enhancements.
> Just a question after a quick look at the doc : can the input file be a
> raster catalog (the gdaltindex thing) ? Raster data needing to be tiled
> fur web publication are sometimes already tiled in several pieces
> because of their size.
> Best regards,
> Guillaume
> Klokan Petr Přidal a écrit :
>> Hello everybody,
>> what was done recently on GDAL2Tiles project:
>> New cool example of the map generated by GDAL2Tiles:
>> I processed freely available USGS DRG map of Grand Canyon by
>> GDAL2Tiles. It is a nice example of what GDAL2Tiles can generate:
>> http://www.maptiler.org/example-usgs-drg-grand-canyon-gtiff/
>> http://www.maptiler.org/example-usgs-drg-grand-canyon-gtiff/usgs-drg-grand-canyon.kml
>> Source Code:
>> - Fully functional source code for generating Google Maps tiles is in
>> my GDAL SVN sandbox (http://svn.osgeo.org/gdal/sandbox/klokan/).
>> The code was refactored a lot and it is almost prepared for merging to
>> stable svn trunk gdal2tiles.py, but some coding is still needed. I am
>> going to work on it during the next week.
>> - I split the code into three files: 'gdal2tiles.py' (the main command
>> line utility), then 'globalmaptiles.py' (classes for global
>> mercator/geodetic tile bounds calculation, runs as command line
>> utility too), and supporting module 'templates.py' with sample HTML
>> viewers and base for generated XML files.
>> - Implementation of several resampling algorithms for controlling the
>> quality of tile rendering. Default is 'average' used in the GDAL's
>> overview functionality. Complete list is:
>> 'average','near','bilinear','cubic','cubicspline','lanczos','antialias'.
>> The last one is high quality Lanczos based antialiasing algorithm, but
>> you will need Python Image Library for that.
>> Quality of the tile rendering is excellent I think. If you need it,
>> the simple and fast 'near' it is still available.
>> - GDAL2Tiles generates the sample Google Maps Based viewer, OpenLayers
>> based Overlay viewer and KML files for Google Earth.
>> - The utility automatically warp the raster to Google Maps projection
>> (EPSG:900913) by AutoCreateWarpedVRT().
>> - For raster files with palette (USGS DRG, NOAA BSB, ...) a separate
>> VRT with "rasterize rgba" (GDAL 1.6dev) is recommended (later I would
>> like to automate this step).
>> The code is NOT YET READY for production use (now supports only RGBA -
>> 4 bands - source files for example), so I recommend you to wait for
>> merged version which will appear in the GDAL trunk. I will send a note
>> when I will finish the merging.
>> Documetation & MapTiler.org
>> - I decided to create a special website for distributing binary
>> installer and user-friendly GUI for GDAL2Tiles. I plan to develop
>> wxWidget based GUI a la step by step wizard. The user-friendly project
>> has name MapTiler, http://www.MapTiler.org/. Right now this web is
>> used only for documentation on for raster files for templates, which I
>> did not want to distribute with utility.
>> I received great feedback from several users and realized that
>> GDAL2Tiles utility is expected by community. That pushed me to crete
>> this new project and change the name to MapTiler, which is more
>> straightforward and fits to the utility probably better, especially
>> for users who are not familiar with GDAL tools yet.
>> GDAL2Tiles will be maintained as GDAL command line utility. MapTiler
>> will implement just GUI and binary distribution.
>> It would be great to have blessing of OSGEO for this project, I would
>> prefer to not make separate SVN repository for such small project,
>> better to keep it as part of GDAL. Would it be possible? Otherwise I
>> will create Google Code project.
>> - I studied the OpenGIS proposal for WMTS standard, which is related
>> to TMS and I plan to send some comments to that standard. Is there
>> still free OSGEO slot for OpenGIS membership?
>> - I created a website about Spherical Mercator and Google Maps
>> Projection and Coordinate system, for anybody who is interested to see
>> the math behind tiles:
>> http://www.maptiler.org/google-maps-coordinate-system-projection-epsg-900913-3785/
>> Question to community:
>> - Would it be possible to keep more files separately even in the main
>> GDAL tree or the utility really have to be merged to one file?
>> - Is there anybody in the OpenLayers community who whould like to have
>> a look at the Opacity Control for OL? I prepared the bitmaps. Is there
>> any need on the OpenLayers templates? Now I am using /dev/ tree of
>> OpenLayers as Virtual Earth support is broken in the stable tree
>> (Safari for example).
>> - Does anybody know how to correctly set the KML SuperOverlay
>> maxlodpixels and fadeextents so transparency and opacity runs well and
>> tiles are not disappearing in Google Earth?
>> - Is anybody interested to help me with developing MapTiler (for
>> example compilation of latest GDAL with all modules, preparing of
>> Windows installer, help with wxPython...)
>> KyngChaos (thank you!) already had a look at binaries for MacOSX, but
>> we did not moved far yet as I need some functionality from 1.6dev.
>> Thanks belong to everybody who gave me excellent advices on #gdal IRC,
>> especially to 'FrankW' and 'even'.
>> BTW I am looking for an interesting job or paid projects... any offers? ;-)
>> Is there anybody who would like to support further development of
>> MapTiler/GDAL2Tiles? There is plenty of features on todo list (merging
>> of produced tiles with existing tile tree, support for MapCruncher
>> tiles, Zoomify tiles, speed improvement - rewrite to C++ to allow
>> better usage of threads on multi-core processors, driver for remote
>> online TMS tiles for GDAL/MapServer to allow WMS from statically
>> published tiles, etc..).
>> Best regards...
>> Klokan Petr Pridal
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.6.5/1618 - Release Date: 8/18/2008 6:51 AM
