[gdal-dev] Support for reading GDAL datasets in compressed
archives(.gz and .zip)
Baumann, Konstantin
Konstantin.Baumann at hpi.uni-potsdam.de
Wed Aug 27 03:00:50 EDT 2008
Hi Even!
That sounds cool. Is there also a function for retrieving all available
files inside of a ZIP archive?
Kind regards,
Kosta
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Monday, August 25, 2008 11:41 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Support for reading GDAL datasets in
> compressed archives(.gz and .zip)
> Folks,
> I've just commited code in gdal 1.6.0dev SVN trunk that
> enables GDAL to
> decompress on-the-fly data from GZIP (.gz) and ZIP (.zip) archives.
> This is implemented as 2 virtual file systems (like /vsimem for
> example), /vsigzip and /vsizip. Only read-only access is supported.
> Note that performance will not be very impressive, as random
> access to ZIP
> file is slow by nature, although some optimizations have been
> made to make it
> faster and generally usable.
> To read from a .gz file,
> gdalinfo /vsigzip/path/to/the/file.gz were
> path/to/the/file.gz is relative or
> absolute.
> The first time that a .gz file is read, a small
> .gz.properties file will be
> generated (if possible) to capture the uncompressed data
> size. This will make
> following opening of that dataset much faster.
> * To read from a .zip file,
> gdalinfo /vsizip/path/to/the/file.zip/path/inside/the/zip/file were
> path/to/the/file.zip is relative or absolute and
> path/inside/the/zip/file is
> the relative path to the file inside the archive.
> For example gdalinfo /vsizip/myarchive.zip/subdir1/file1.tif
> The ReadDir() method is implemented for the .zip archives, so
> a driver will be
> able to find files relative to the given file inside the archive. For
> example, you can read a CADRG dataset from the zipped archive
> of the a.toc
> file and all its NITF tiles.
> Small syntaxic sugar : if the .zip file contains only one
> file located at its
> root, just mentionning "/vsizip/path/to/the/file.zip" will work.
> The fact that this new capability is implemented as virtual
> file systems imply
> that it will only work for GDAL drivers supporting the "large
> file API". A
> list of such drivers is : PNG, JPEG, ILWIS, GTiff, GIF,
> JP2KAK, NITF, ADRG,
> DTED, SRTMHGT, BMP, LCP, HFA (Erdas Imagine), AAIGRID. Other
> drivers may work
> too (I just looked for those advertizing the
> GDAL_DCAP_VIRTUALIO capability)
> (See http://trac.osgeo.org/gdal/ticket/1369 for the history
> of that feature.)
> Best regards
> Even
