[gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf
Even Rouault even.rouault at mines-paris.org
Wed Aug 27 16:50:14 EDT 2008
Any chance that you are building GDAL with HDF4 support too ?
http://trac.osgeo.org/gdal/wiki/NetCDF says :
"If building GDAL with both HDF4 and NetCDF support it is necessary to build
the HDF library specially or a dangerous conflict will occur. See the
http://trac.osgeo.org/gdal/wiki/HDF topic for details."
On my ubuntu 7.04, the hdf4 library coming from the .deb is not build properly
as indicated in the wiki and GDAL does crash.
Le Wednesday 27 August 2008 22:38:04 Vishal Mehta, vous avez écrit :
> Hello all,
> I continue to have 'segmentation fault' error using gdal-1.5.2 on Ubuntu
> 8.04 with netcdf files.
> I re-compiled gdal from source again, this time with Dylan Beaudette's
> gracious help (thanks Dylan!). I still got segmentation fault.
> Below are the last few lines of strace - hope that helps in identifying
> what the problem is... I have libnetcdf 3.6-2-2
> Please note that the two netcdf files I've tried do open using FWTools for
> Windows as well as starspan for Windows - so I don't think anything is
> wrong with the netcdf files..
> -vishal
> -------excerpt from strace follows---
> read(3, "CDF\1\0\0\0\1\0\0\0\n\0\0\0\3\0\0\0\3lat\0\0\0\1h\0\0\0"..., 4096)
> = 4096 _llseek(3, 0, [0], SEEK_SET)            = 0
> open(".", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|0x80000) = 4
> fstat64(4, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
> fcntl64(4, F_GETFD)                     = 0x1 (flags FD_CLOEXEC)
> getdents(4, /* 6 entries */, 4096)      = 136
> getdents(4, /* 0 entries */, 4096)      = 0
> close(4)                                = 0
> open("airtemp.nc", O_RDONLY|O_LARGEFILE) = 4
> fstat64(4, {st_mode=S_IFREG|0666, st_size=265644, ...}) = 0
> _llseek(4, 0, [0], SEEK_SET)            = 0
> read(4, "CDF\1\0\0\0\1\0\0\0\n\0\0\0\3\0\0\0\3lat\0\0\0\1h\0\0\0"..., 8192)
> = 8192 --- SIGSEGV (Segmentation fault) @ 0 (0) ---
> +++ killed by SIGSEGV +++
> Process 395 detached
