[gdal-dev] Topological Union?
Mateusz Loskot mateusz at loskot.net
Fri Aug 29 13:21:45 EDT 2008
Craig Miller wrote:
> Thanks Brent.  I'm looking for a C/C++ solution.  I'll take a look at
> the other polygon processing libraries as well as the level of effort
> in porting JTS Cascaded Unions to Geos... that's a conversation for a
> different mailing list though.
Craig,
I agree with Brent that performance is/may not be very impressive.
In OGR, this is mostly caused by a need to convert OGRGeometry type to
GEOS geometry type [1] - allocating & copying coordinates data is expansive.
However, if you are developing your own solution in C++, you can avoid
this by defining your geometry in terms of interface of
geos::geom::Geometry or - following design pattern called adapter,
you can provide a thin wrapper on your geometry type that will make it
accessible to GEOS engine. This way you should get rid of major
bottleneck of OGR<->GEOS interoperability.
[1] http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrgeometry.cpp#L2105
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
