[gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf
Francesco Paolo Lovergine frankie at debian.org
Sat Aug 30 16:31:20 EDT 2008
On Wed, Aug 27, 2008 at 11:41:44PM +0200, Even Rouault wrote:
> Vishal,
> you can use both netcdf and HDF4, but you'll have to uninstall the HDF4
> library packaged by Ubuntu, and compile it from the source with the
> instructions given in the wiki.
> Maybe worth reporting that to Debian/Ubuntu packagers if there's something
> they can do to build a compatible HDF4 library by default.
It is already known and reported by me in BTS for Debian.
HDF4 in Debian is fixed in experimental but it is too late for Lenny, sorry.
Francesco P. Lovergine
