[gdal-dev] autotest 1.6 errors - need help
Mon Dec 1 12:25:36 EST 2008
William Kyngesburye wrote:
> On Nov 30, 2008, at 4:03 PM, William Kyngesburye wrote:
>> - tiff_write
>>  TEST: tiff_write_55 ... PROJCS["Equirectangular
>> Mars",GEOGCS["GCS_Mars",DATUM["unknown",SPHEROID["unnamed",3394813.857975945,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Equirectangular"],PARAMETER["latitude_of_origin",-2],PARAMETER["central_meridian",184.4129943847656],PARAMETER["standard_parallel_1",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
>> fail
>>    failed to preserve Equirectangular projection as expected, old
>> libgeotiff?
>> Well, I'm using geotiff 1.2.5, and I notice that GDAL includes 1.2.4.
>> It's not saying what the difference is.
> Tried with internal geotiff, no change.
> Also note: I'm using a CVS trunk libtiff from Mar 2008.
William,
This is a problem in the autotest suite.  I have not yet uploaded the
corrected version.
Best regards,
