[gdal-dev] GDAL/OGR 1.6.0 Release Candidate 2
Mon Dec 1 16:11:49 EST 2008
Stephen Woodbridge wrote:
> I just checked RC2 this against the jp2 problem we have been struggling
> with. I believe the patch you made or this is in RC1 and RC2. See below.
> MrSID: RasterIO() - using optimized dataset level IO.
> MrSID: Dataset:IRasterIO(25432,42149 5066x6973 -> 5066x6973 ->
> 5066x6973, zoom=1)
> gdalwarp: ../compressed/compressed.cpp:1724: bool
> kd_tile::read_tile_part_header(): Assertion `tpart_body_length >= 0'
> failed.
Steve,
I have come to the conclusion you are not encountering the 32bit window
overflow problem that I fixed - though it was striking another client of
mine.   I don't seem to have a way of reproducing your problem, so there
isn't much else I can do to dig into it.
Best regards,
