[gdal-dev] is MrSid SDK (7.0.0.2167) supported by GDAL
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 1 17:19:45 EST 2008
Hi all,
Quick question, Is MrSid SDK (7.0.0.2167) supported by GDAL?
As indicated by the release notes 4. there are fixes to the JP2 readers
and I'm wondering if that might resolve my JP2 issue since I'm currently
on: MrSid SDK 6.0.7.1407
Thanks,
-Steve
Release Notes for SDK (7.0.0.2167)
5/28/2008
1. *** API CHANGE *** As described in the Porting Guide
section of the User Manual, breaking changes have been
introduced to the API, in order to address the needs of
more flexible workflows and pipelines in applications.
This will require small changes to existing code.
2. The LTIOFileStream class now support +2GB files. The
LTIOFileStream64 class has been removed.
3. The mix of supported platforms has been updated. See
platforms.txt for details.
4. A number of bugs have been fixed in the JP2 and NITF
readers and writers.
5. Small performance improvements have been made in many
areas of the code.
6. Member functions that are not documented (or are
explicitly marked as LizardTech-only) should in general
not be used by third-party developers.
