[gdal-dev] build error in trunk
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Wed Dec 3 08:15:17 EST 2008
On fc9, with:
./configure --with-png --with-libtiff=internal --with-geotiff=internal
--with-jpeg --with-xerces --with-geos=no --with-pg=/usr/bin/pg_config
--with-mysql=/usr/bin/mysql_config -
-with-sqlite --with-curl=/usr/bin/curl-config --with-python --with-expat
/gdal/gcore -I/home/tkralidi/foss4g/gdal/trunk/gdal/alg
-I/home/tkralidi/foss4g/gdal/trunk/gdal/ogr
-I/home/tkralidi/foss4g/gdal/trunk/gdal/ogr/ogrsf_frmts -DOGR_ENABLED
-I/home/tkralidi/foss4g/gdal/trunk/gdal/port  -c -o gdalsievefilter.lo
gdalsievefilter.cpp
libtool: compile:  g++ -g -O2 -Wall
-I/home/tkralidi/foss4g/gdal/trunk/gdal/gcore
-I/home/tkralidi/foss4g/gdal/trunk/gdal/port -c gdalsievefilter.cpp
-fPIC -DPIC -o .libs/gdalsievefilter.o
-I/home/tkralidi/foss4g/gdal/trunk/gdal/port -c gdalsievefilter.cpp -o
gdalsievefilter.o >/dev/null 2>&1
make[1]: *** No rule to make target `gdalprofile.lo', needed by
`default'.  Stop.
make[1]: Leaving directory `/home/tkralidi/foss4g/gdal/trunk/gdal/alg'
make: *** [core-target] Error 2
