[gdal-dev] Re: Looking for advice on finding neighboring features
sgillies at frii.com sgillies at frii.com
Wed Dec 3 15:39:12 EST 2008
> I'm no expert, but I have some thoughts.
> A) this really isn't a GDAL issue -- GDAL is about reading ant writing
> the data -- you're interested in processing. you might want to look at
> the geos lib.
>> In order to get this profile, I want to do a spatial query on DEM
>> shapefiles
> DEMs are usually gridded data -- a shapefile is odd for this. Is it
> gridded?
>> someone gives me a large shapefile, e.g. that of a whole country, I
>> don't know if computationally it's reasonable to perform a proximity
>> check on every single feature in the shapefile. I suppose this would
>> be O(2), which could get quite expensive/long for a microprocessor or
>> some kind of embedded platform.
> yup.
> What you need is a spatial index. I think shapelib has one built in --
> you load the shapefile, index it, and then these sorts of neighbor
> queries are fast. (order logN, I think).
> You could also use:
> http://trac.gispython.org/spatialindex/wiki/
> and there are python bindings for geos and rtree:
> http://pypi.python.org/pypi/Rtree
> http://pypi.python.org/pypi/Shapely/1.0.11
> which may be helpful for prototyping.
>> What I was hoping to discover is whether shapefiles have some field in
>> a feature that says what other features share common points.
> nope -- they are pretty simple, really.
> -Chris
Spatialindex/Rtree also support efficient queries for the N nearest
neighbors.
FWTools includes a program called shptree, which makes quad trees for
shapefiles. Once you have one of those, you could find all neighbors
fairly efficiently using nothing other than ogr.py.
Cheers,
Sean
