[gdal-dev] How to CreateCopy a dataset from an empty virtual dataset (no source dataset is linked)?
Tue Dec 9 18:09:19 EST 2008
Qingfeng (Gene) Guan wrote:
> I am trying to write a program which is able to create a raster dataset
> of any supported format. To do so, I first created a virtual dataset in
> memory using the Create() function, then set the projection and add the
> bands to the virtual dataset (no links to source datasets), and then
> used the CreateCopy() function to create a non-virtual dataset from the
> virtual dataset I just created. However, the CreateCopy() always
> returned a NULL pointer. I also tried creating a temporary vrt file
> using the Create() function before using CreateCopy(). Still, the
> CreateCopy() returned a NULL pointer.
> Has anyone done this before or have any idea how to do this? Do I have
> to link a source dataset to the virtual dataset before using
> CreateCopy() to create a non-virtual dataset from the virtual dataset? I
> just want to create an empty dataset in which all the pixels are set to
> some initial value (for example, zero).
> I am using GDAL 1.5.3. <http://1.5.3./> The following is the code I wrote:
> GDALDriver *poDriver = (GDALDriver *) GDALGetDriverByName( "VRT" );
> GDALDataset *poVRTDS;
> poVRTDS = poVRTDriver->Create("", xSize, ySize,
>                             3, GDT_Byte,
>                             NULL);
Gene,
It turns out that VRTSourcedRasterBand::IRasterIO() returns CE_Failure if
there are no sources for the band.  I believe this is an inappropriate
behavior, and unnecessarily interferes in situations like yours.
I would appreciate your filing a trac ticket on the issue, and I'll look
into applying a fix.  Tentatively I'm considering this change
in gdal/frmts/vrt/vrtsourcedrasterband.cpp:
Index: vrtsourcedrasterband.cpp
--- vrtsourcedrasterband.cpp    (revision 15924)
+++ vrtsourcedrasterband.cpp    (working copy)
@@ -122,7 +122,7 @@
      int         iSource;
-    CPLErr      eErr = CE_Failure;
+    CPLErr      eErr = CE_None;
      if( eRWFlag == GF_Write )
@@ -171,7 +171,7 @@
  /*      Overlay each source in turn over top this.                      */
-    for( iSource = 0; iSource < nSources; iSource++ )
+    for( iSource = 0; eErr == CE_None && iSource < nSources; iSource++ )
          eErr =
              papoSources[iSource]->RasterIO( nXOff, nYOff, nXSize, nYSize,
You might want to try it yourself.
Best regards,
