[gdal-dev] gdalwarp cutting off projected image
Scott Lewis
scott.lewis at nsidc.org
Tue Dec 9 18:33:13 EST 2008
Frank,
The image I've been trying to convert is at this URL. It's about 6MB,
hopefully that's not too big.
ftp://sidads.colorado.edu/pub/incoming/glewis/polar.gtiff.tif
Basically, I'm trying to convert it to a plain-old EPGS:4326 (latlong
projection).
I appreciate you taking a look.
Scott
PS - I'm still new to the GDAL list; when you say file a Trac ticket,
where would I do this?
Scott Lewis wrote:
> I've been having problems getting it staged. As soon as I'm able to
> I'll send the URL. Maybe the source geotiff file doesn't have the
> information necessary to convert correctly, perhaps.
> Again, thanks for your help. Hopefully I'll have the URL soon.
> Scott
> Frank Warmerdam wrote:
>> Scott Lewis wrote:
>>> Frank,
>>> Thanks for the help. I tried doing this, and ended up with the same
>>> image (even diff found them to be the same). Here are the various
>>> commands I tried. Maybe I'm just using the -wo option wrong.
>>> gdalwarp -t_srs EPSG:4326 -wo SOURCE_EXTRA=1000 input.gtiff.tif
>>> output1.gtiff.tif
>>> gdalwarp -t_srs EPSG:4326 -wo "SOURCE_EXTRA=1000" input.gtiff.tif
>>> output2.gtiff.tif
>>> gdalwarp -t_srs EPSG:4326 -wo "SOURCE_EXTRA=1000 SAMPLE_GRID=YES
>>> SAMPLE_STEP=100" input.gtiff.tif output3.gtiff.tif
>>> I'll continue to play with those options, though. gdalwarp seems to
>>> not act any different (IE, it takes the same amount of time to
>>> process) with or without the -wo option, so I'm thinking I'm just
>>> not using the option correctly somehow.
>>> Again, I appreciate your help!
>> Scott,
>> I suspect I've misconstrued what is going wrong. If you can stage
>> the input file somewhere, and if it isn't too terribly huge, I would
>> be interested in trying it myself. Ideally this could be filed as a
>> Trac ticket.
>> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
