[gdal-dev] shapefile->mysql join problem
William Kyngesburye woklist at kyngchaos.com
Fri Dec 12 13:12:38 EST 2008
I trying to do a shapefile to mysql join:
ogrinfo -al -so -sql "SELECT * FROM st99_d00 LEFT JOIN
'MYSQL:mydb
,host=localhost,user=me,password=,tables=state_sum'.state_sum ON
st99_d00.state = state_sum.stfips" st99_d00.shp
This works if the state_sum.stfips field is not indexed at all, or has
a non-unique index.  But when I use a primary key or unique index (the
stfips field IS unique), I get an error:
ERROR 1: SQL: Unrecognised secondary field st99_d00.state in JOIN
clause..
Intended behavior?  Bug?  Or I'm doing it wrong?  I suppose if some
form of index works, though not unique, the lookup won't be slow.
Note that this is really for a mapserver mapfile, but since it doesn't
work directly in OGR I'm asking here.
DATA "SELECT * FROM st99_d00 LEFT JOIN
'MYSQL:mydb
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
