[gdal-dev] Coordinate Transformation Question
Frank Warmerdam
warmerdam at pobox.com
Tue Dec 16 14:56:23 EST 2008
Joel Odom wrote:
> Is it possible to transform between a Lambert projection (NAD83 datum)
> and WGS84 geographic? I'm trying the following, but poCT is null:
> OGRSpatialReference oSRS;
> if (oSRS.importFromWkt((char**)&projectionRef) != OGRERR_NONE)
> OGRSpatialReference wgs84;
> wgs84.SetWellKnownGeogCS("WGS84");
> OGRCoordinateTransformation *poCT =
> OGRCreateCoordinateTransformation(&oSRS, &wgs84);
> In this case oSRS is the Lambert Conformal / NAD83. Thanks for any help.
Joel,
Yes, this should work fine assuming thereis nothing funky about your
LCC projection definition. Note that OGR/PROJ.4 consider NAD83 and WGS84
to be equivelent datums for transformation purposes.
If you post your projection string for the LCC I could try it here for
comparison.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
