[gdal-dev] help! convert GML to Shp by using python
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 18 11:52:32 EST 2008
Xiaoyu Guan wrote:
> Hi Frank:
> Thanks very much for your reply.
> About GML files, actually, I grab The GML files from OpenLayers.org.
> as you know OpenLayers can read GML files directly.
> The GML which i used is located at
> http://www.openlayers.org/dev/examples/gml/multipolygon.xml
> You have to change xml to gml by yourself.
> The commend which I used for converting is that
> > ogr2ogr -f "ESRI Shapefile" polygon.shp multipolygon.gml
> the above commend will create few shp files, so I have also tried
> another one
> > ogr2ogr -f "ESRI Shapefile" polygon.shp multipolygon.gml multipolygon
> this one will create one shapefile.
> but the polygon.shp file does not contain the first feature's and the
> third feature's attribute
Xiaoyu,
I tried a translation like:
ogr2ogr out.shp multipolygon.xml
and this seemed to produce a shapefile with all three features, and all
their attributes (ogc_fid, name, id). I did this with GDAL/OGR trunk -
essentially identical to 1.6.0.
I observe that this gml file is produced by MapServer, and there should
be no need to rename it with a .gml extension.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
