[gdal-dev] Zonal statistics with GDAL/StarSpan
Greg Ederer
greg at ergonosis.com
Thu Dec 18 15:26:25 EST 2008
Thanks, Brent. I'll give this a whirl.
Cheers,
Greg
Brent Fraser wrote:
> Greg,
> OpenJump is a good topology/geometry fixing tool. Load your
> shapefile and do Tools->Generate->Buffer, set the Buffer distance to 0
> to clean up the polygon vertices. I seem to recall it may have a
> problem preserving attributes when the results are saved as a
> shapefile, but you may be able to just use the new .shp portion with
> the old .dbf and .shx if the resulting geometry records are not
> re-ordered.
> Brent
> Greg Ederer wrote:
>> Brent,
>> My Google search didn't turn up much of use (most of the results were
>> PostGIS-specific). Do you know of a tool that would tell me which
>> feature(s) have problems? Do you know of a tool that might be able
>> to fix these polygons?
>> Thanks!
>> Greg
>> Brent Fraser wrote:
>>> Greg,
>>> It means the GEOS topology library is having problems with geometry
>>> of your input shapefile. Most likely related to duplicate vertices
>>> (or near-duplicate) in a polygon. Do a Google for "side location
>>> conflict". It would be nice if it spat out the FID of the
>>> offending polygon...
>>> Brent
>>> Greg Ederer wrote:
>>>> Hi Brent,
>>>> Thanks for the example. Here's what I got:
>>>> Macintosh-4:starspan_tests gregederer$ starspan2 --progress --RID
>>>> none --vector
>>>> /Users/gregederer/servers/geoserver_data/data/shapefiles/Admin/afadmn2n.shp
>>>> --raster rfe_2006_04_pct.tif --stats results.txt avg
>>>> starspan: --out-prefix: ?
>>>> Type `starspan --help' for help
>>>> I then added a --out-prefix, like so:
>>>> none --vector
>>>> --raster rfe_2006_04_pct.tif --stats results.txt avg --out-prefix bar
>>>> starspan: --out-type: ?
>>>> I then added '--out-type table' (I found in the source that valid
>>>> --out-types are: table, mini_raster_strip, mini_rasters,
>>>> rasterization):
>>>> none --vector
>>>> bar --out-type table
>>>> Number of features: 550
>>>> starspan_csv: 1: Extracting from rfe_2006_04_pct.tif
>>>> 0% terminate called after throwing an instance of
>>>> 'geos::util::TopologyException'
>>>> what(): TopologyException: side location conflict -8.25 23.1536
>>>> Abort trap
>>>> Any idea what the TopologyException indicates?
>>>> Thanks!
>>>> Greg
>>>> Brent Fraser wrote:
>>>>> Greg,
>>>>> I've used StarSpan to do similar things; in my case I wanted
>>>>> "mode" not "avg". Using v1.2.01 (I don't think I made major mods
>>>>> to the source):
>>>>> starspan2.exe --progress --RID none --vector boundaries.shp
>>>>> --raster big.tif --stats results.txt mode
>>>>> I edited the resulting results.txt text (csv) file and used GDAL's
>>>>> ogr2ogr to do a join on the shapefile's DBF file based on the FID.
>>>>> Brent Fraser
>>>>> Greg Ederer wrote:
>>>>>> Hello all,
>>>>>> I'm a GDAL newbie. I have a shape file containing subnational
>>>>>> boundaries for Africa. I have a raster containing rainfall for
>>>>>> Africa. I need to pull out the spatial average of rainfall for
>>>>>> each of the subnational units.
>>>>>> I think that I might be able to pull this off using StarSpan.
>>>>>> But, the docs on the StarSpan wiki do not line up with the
>>>>>> current version of the program (the changelog mentions that
>>>>>> certain command line switches have been eliminated, and others
>>>>>> added; but it doesn't say what the new switches do, or how to use
>>>>>> them). I am digging through the StarSpan sources to try to
>>>>>> figure out how to use it.
>>>>>> Does anyone have any suggestions as to how I might get the needed
>>>>>> data using GDAL (with, or without StarSpan)?
>>>>>> Thanks!
>>>>>> Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| 360.774.6848
