[gdal-dev] Debugging on Windows Using Visual Studio
    Frank Warmerdam
    warmerdam at pobox.com
    Fri Dec 19 11:10:26 EST 2008
Joel Odom wrote:
> Bruce.  I'm trying to debug an app that uses GDAL from unmanaged C++
> on Visual Studio 2005.  I've tried for an hour or two to step into
> gdal, running debug sessions both from the project file from which I
> build gdal and from the app that calls into GDAL, but even when I run
> from the gdal solution itself, it still doesn't let me step through
> source code, even though the modules window says gdal15.dll is loaded
> with symbols from the same location as my .pdb file.
Joel,
I have generally not had problems with this.  Did you build GDAL using
the nmake files or the solution?  I've had good luck debugging the
utilities and into GDAL itself with visual studio. I normally run things
from the commandline and pop into visual studio when things crash (even
triggering crashes at select points).
This is usually with visual studio 2003.
Best regards,
