[gdal-dev] Zonal statistics with GDAL/StarSpan
Brent Fraser bfraser at geoanalytic.com
Fri Dec 19 18:13:11 EST 2008
> Hi,
> I performed the OpenJump procedure.  But, I still get:
> Macintosh-4:starspan_tests gregederer$ starspan2 --progress --RID none
> --vector afadmn2n.shp --fid 3  --raster rfe_2006_04_pct.tif --stats
> results.txt avg --out-prefix bar --out-type table
> Number of features: 550
> starspan_csv:   1: Extracting from rfe_2006_04_pct.tif
>         0% terminate called after throwing an instance of
> 'geos::util::TopologyException'
>   what():  TopologyException: side location conflict -8.25 23.1536
> Abort trap
> So:
> a) Is there some way to get a dump of FIDs with their corresponding
> country/province names?
You could use dbfdump.  I think it is delivered with FWTools.
> b) What other steps might I take to detect/fix any side location
> conflict(s)
I've attached the source to a GDAL application I wrote (it simply accesses
the GDAL/Geos buffer function) to repair geometry of polygons.  Use the -r
option (the -c option doesn't work).  You'll need to link with a version
of GDAL that uses GEOS.
> c) The docs on the starspan wiki are out of sync with the current
> version (1.2.03).  Are there updated docs for starspan?  Should I fall
> back to a previous version?
I used version 1.2.01, but I don't recall why...
Brent
/*  ***************** SOURCE HEADER: **********************
Name:
Purpose:
Invocation:
Arguments:
Data Files Accessed:
Program History:
		v1.0	19 Jun	2007	BWF	initial coding
Note:
Algorithm Description:
Future Enhancements:
***************   End of SOURCE HEADER  ************** */
#include <assert.h>
#include "GDAL.h"
#include "cpl_string.h"
#include "ogrsf_frmts.h"
static void Usage()
    printf(
		"ogrClean v1.0\n"
		"Create clean planar polygon layer from overlapping polygons.\n"
        "Usage: ogrClean -a <input>            Assigned unique integer to FID attribute\n"
        "       ogrClean -r <input>            Repair topology\n"
        "       ogrClean -c <input>            Create non-overlapping topology\n"
		"       ogrClean -d <input> <output>   Delete records with NULL geometry.\n"
    exit( 1 );
void notice(const char *fmt, ...)
    va_list ap;
        fprintf( stdout, "NOTICE: ");
    va_start (ap, fmt);
        vfprintf( stdout, fmt, ap);
        va_end(ap);
        fprintf( stdout, "\n" );
void log_and_exit(const char *fmt, ...)
    va_list ap;
        fprintf( stdout, "ERROR: ");
    va_start (ap, fmt);
        va_end(ap);
    exit(1);
int repairPolygons(const char *pszSrcFilename, bool bOpAssignFID, bool bOpRepairTopo )
    OGRDataSource	*poDS;
    OGRLayer		*poLayer;
	OGRFeature		*poFeature;
	OGRGeometry		*poGeometry;
	OGRwkbGeometryType poGeomType;
	char *pszGeom=NULL;
	OGRErr oErr;
	long nLayers=0;
	long nFeatures=0;
	bool bFoundFID;
    int iField;
	long i=0, id=0;
	long iCountFixed=0;
	bool bGeomUpdated = false;
	/*  Open input:                                                          */
	OGRRegisterAll();
    poDS = OGRSFDriverRegistrar::Open( pszSrcFilename, TRUE );	// we will be updating the dataset
    if( poDS == NULL )
		return(1);	//can't open dataset
    nLayers = poDS->GetLayerCount();
	if (nLayers == 0)
		return(2);	//no layers in dataset
	// TBD: allow mult layers:
    poLayer = poDS->GetLayer( 0 );
    poLayer->ResetReading();
	nFeatures = poLayer->GetFeatureCount();
    if ( (poFeature = poLayer->GetNextFeature()) != NULL )
		//--- Check Geometry type: ---//
        poGeometry = poFeature->GetGeometryRef();
        if( poGeometry != NULL )
			poGeomType = poGeometry->getGeometryType();	// TBD: check if polgon
			if ( poGeomType != wkbMultiPolygon && poGeomType != wkbPolygon )
				printf("Data must be polygons.\n");
		}else
			return(4);	//no geometry in feature
		//--- Get Field of unique ID: ---//
		bFoundFID = false;
        OGRFeatureDefn *poFDefn = poLayer->GetLayerDefn();
        for( iField = 0; iField < poFDefn->GetFieldCount(); iField++ )
            OGRFieldDefn *poFieldDefn = poFDefn->GetFieldDefn( iField );
			if ( EQUAL(poFieldDefn->GetNameRef(),"FID") )
				bFoundFID =  true;
				break;
		if (!bFoundFID)
			printf("Data must have a unique ID field called FID.\n");
			return(5);
	}else
		printf("No features in dataset.\n");
		return(3);	//no features in dataset
	/*  Process Features:                                                    */
	i=0;
	while( (poFeature = poLayer->GetNextFeature()) != NULL )
		GDALTermProgress( ((double)i)/nFeatures, "", NULL);
		if ( bOpAssignFID )
			id = i;
		}else
			id = poFeature->GetFieldAsInteger(iField);
//		printf("%d. FID %d\n", i, id);
		if ( bOpRepairTopo && poFeature->GetGeometryRef() )  //not null
			poGeometry = poFeature->GetGeometryRef()->clone();	// make a copy of geometry, otherwise there's a problem re-assigning it later.
			if ( poGeomType != wkbMultiPolygon && poGeomType != wkbPolygon )	// not a polygon!
				printf("** Warning. FID %d has geometry type of %s.\n", id, poGeometry->getGeometryName() );
				poGeometry->exportToWkt(&pszGeom);
				printf("%s\n",pszGeom );
			if ( !poGeometry->IsValid() )	// need to fix, so...
//				printf("Warning. FID %d has invalid topology.\n", id);
				OGRGeometry *poTempGeometry = poGeometry->Buffer(0.0);  // Let Geos fix the problem.
				if (poTempGeometry)	// not sure how it could be null...
					if ( poTempGeometry->IsValid() )
//						printf("  Can correct by buffering.\n");
						poGeometry = poTempGeometry->clone();	//replace with this new geom (need to destroy old?)
						oErr = poFeature->SetGeometry(poGeometry);
						bGeomUpdated = true;
						iCountFixed++;
					}else
						printf("** Warning. FID %d still has invalid topology after buffering (so not updated).\n", id);
				}else
						printf("** Warning. FID %d has NULL geometry after buffering (so not updated).\n", id);
				if (poTempGeometry != NULL)
					OGRGeometryFactory::destroyGeometry( poTempGeometry);
					poTempGeometry = NULL;
			}else // valid
				if ( poGeometry->IsEmpty() )
//					printf("Warning. FID %d has empty geometry.\n", id);
			if (poGeometry != NULL)	// can delete since SetGeometry makes a copy
				OGRGeometryFactory::destroyGeometry( poGeometry);
				poGeometry = NULL;
		}else
//			printf("Warning. FID %d has NULL geometry.\n", id);
		if ( bOpAssignFID )
			poFeature->SetField( iField, id );
		if ( bGeomUpdated || bOpAssignFID )
			oErr = poLayer->SetFeature(poFeature);
//			poDS->SyncToDisk();
		OGRFeature::DestroyFeature( poFeature );
		i++;	//first record is 0
	GDALTermProgress( ((double)nFeatures)/nFeatures, "", NULL);
	if ( bOpRepairTopo )
		printf("\n-- Info: Fixed %d polygons.\n", iCountFixed );
	OGRDataSource::DestroyDataSource( poDS );
	return(0);
int cleanPolygons(const char *pszSrcFilename, const char *pszAdjFilename ) //, const char *pszDstFilename, const char *pzsDstFormat)
    OGRLayer		*poLayer;
	OGRDataSource	*poDSadjacent;
	OGRLayer		*poLayerAdjacent;
	OGRFeature		*poFeatureAdjacent;
	long nLayers;
	char *pszGeom=NULL;
	OGRErr oErr;
	long i=0;
	long nFeatures=0;
	unsigned int nCoords=0;
//	double x, y;
    int iField;
	int id, idAdjacent;
	bool bFoundFID;
	bool bDone=false;
	/*  Open input:                                                          */
	OGRRegisterAll();
    if( poDS == NULL )
	if (nLayers == 0)
		}else
		bFoundFID = false;
				bFoundFID =  true;
				break;
		if (!bFoundFID)
			return(5);
	}else
//    poDSadjacent = OGRSFDriverRegistrar::Open( pszSrcFilename, FALSE );	// read only
//	if( poDSadjacent == NULL ) return(1);	//can't open dataset
//    poLayerAdjacent = poDSadjacent->GetLayer( 0 );
	i=0;
		i++;
		if ( poFeature->GetGeometryRef() )  //not null
			if (!poGeometry->IsValid() )
				printf("Warning. FID %d has invalid geometry, buffering to fix.\n", id);
				poGeometry = poGeometry->Buffer(0.0);
			//---- Set Spatial Filter to only this Poly-of-interest ---//
			if ( pszAdjFilename )
				poDSadjacent = OGRSFDriverRegistrar::Open( pszAdjFilename, FALSE );	// read only
			}else
			poLayerAdjacent->SetSpatialFilter(poGeometry);
			poLayerAdjacent->ResetReading();
			//--- Get Adjacent Polys: ---//
			bDone = false;
			while( ((poFeatureAdjacent = poLayerAdjacent->GetNextFeature()) != NULL) && ! bDone ) // more polys nearby and some poly geom left
				OGRGeometry *poGeometryAdjacent = poFeatureAdjacent->GetGeometryRef();  // no need to clone since need read only
				idAdjacent = poFeatureAdjacent->GetFieldAsInteger(iField);
				if ( poGeometryAdjacent )  //might have null geom? YES (due to this processing)
					if (!poGeometryAdjacent->IsValid() )
						poGeometryAdjacent = poGeometryAdjacent->Buffer(0.0);
					if ( ( id!=idAdjacent || pszAdjFilename ) && (
						!poGeometryAdjacent->IsEmpty() &&
						poGeometryAdjacent->IsValid() &&
						poGeometryAdjacent->Intersects(poGeometry)) )	//has some geom and not the same poly
						OGRGeometry *poTempGeometry = poGeometry->Difference(poGeometryAdjacent);  // subtract the adj poly
							poGeomType = poTempGeometry->getGeometryType();	// make sure a poly is the result (will be linestring for shared boundary)
							if ( poGeomType == wkbMultiPolygon || poGeomType == wkbPolygon )
								if (!poTempGeometry->IsValid() )
									poTempGeometry = poTempGeometry->Buffer(0.0);
										printf("Warning. FID %d - FID %d resulted in invalid geometry, even after buffering.\n", id, idAdjacent);
								}else
									//poGeometry->exportToWkt(&pszGeom);
									//printf("%d - %d: %s\n", id, idAdjacent, pszGeom);
							}else	// not a polygon
								if ( !poTempGeometry->IsEmpty())
									printf("Warning. FID %d now has geometry type of %s.\n", id, poTempGeometry->getGeometryName() );
									poTempGeometry->exportToWkt(&pszGeom);
								}else	// empty "other" (GEOMETERYCOLLECTION) geometry
//									printf("Warning. FID %d now has empty geometry.\n", id );
									bDone = true;
						}else  // null polygon geom
							poGeometry = poTempGeometry;
							printf("Warning. FID %d now has NULL geometry.\n", id );
							bDone = true;
					}else
						if (poGeometryAdjacent->IsEmpty())
								printf("  Warning. Adjacent FID %d has empty geometry.\n", idAdjacent);
						if (!poGeometryAdjacent->IsValid())  // attempted to buffer above, so don't bother again
								printf("  Warning. Adjacent FID %d has invalid geometry.\n", idAdjacent);
					OGRGeometryFactory::destroyGeometry( poGeometryAdjacent );	// done with this nearby poly
					poGeometryAdjacent = NULL;
				}else	// null geom
					//printf("  Warning. Adjacent FID %d has NULL geometry.\n", idAdjacent);
				//OGRFeature::DestroyFeature( poFeatureAdjacent );
			}  //no more nearby polys
			OGRDataSource::DestroyDataSource( poDSadjacent );
			if ( bGeomUpdated )
				if ( poGeometry )
					//--- Set the new clipped geometry: ---//
					if (poGeometry->getGeometryType() == wkbMultiPolygon || poGeometry->getGeometryType() == wkbPolygon )
					}else
						oErr = poFeature->SetGeometry(NULL);	//tbd: delete feature?
					if (poGeometry->IsEmpty())
				} else
				poDS->SyncToDisk();
				poGeometry = NULL;
		}else	 // null geom
//			printf("Warning. FID %d has NULL geometry.\n", id );
    }	// end of polys
	/*  close Datasources:                                                   */
//	OGRDataSource::DestroyDataSource( poDSadjacent );
	return(0);
int deleteNullPolygons(const char *pszSrcFilename, const char *pszDstFilename, const char *pzsDstFormat)
    OGRLayer		*poLayer;
	OGRFeatureDefn  *poFDefn;
	OGRDataSource	*poDSout;
	OGRLayer		*poLayerOut;
	OGRFeature		*poFeatureOut;
	long nLayers, nFeatures;
	int i;
	int iFiltered=0;
	bool bFoundFID=false;
	bool bAssignFID=false;
	int iField=0;
	/*  Open input:                                                          */
	OGRRegisterAll();
    poDS = OGRSFDriverRegistrar::Open( pszSrcFilename, FALSE );	// we will NOT be updating the dataset
    if( poDS == NULL )
		printf("Failed to open dataset: %s\n",pszSrcFilename);
	if (nLayers == 0)
		}else
	}else
	bFoundFID = false;
			bFoundFID =  true;
			break;
	/*  Create output:                                                       */
	OGRSFDriver *poDriver;
    poDriver = OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName( pzsDstFormat );
    if( poDriver == NULL )
//        printf( "%s driver not available.\n", pszDriverName );
        return(101);
	poDSout = poDriver->CreateDataSource( pszDstFilename, NULL );
    if( poDSout == NULL )
//        printf( "Creation of output file failed.\n" );
        return(102);
	poLayerOut = poDSout->CreateLayer( "new_layer", NULL, poGeomType, NULL );
    if( poLayerOut == NULL )
//        printf( "Layer creation failed.\n" );
        return(103);
    for(iField = 0; iField < poFDefn->GetFieldCount(); iField++ )
		if( poLayerOut->CreateField( poFieldDefn ) != OGRERR_NONE )
	//        printf( "Creation of field failed.\n" );
			return(104);
	if (!bFoundFID)
		OGRFieldDefn oField( "FID", OFTInteger );
		bAssignFID = true;
		if( poLayerOut->CreateField( &oField ) != OGRERR_NONE )
			printf( "Creating FID field failed.\n" );
			return(5);
	bFoundFID = false;
    poFDefn = poLayerOut->GetLayerDefn();
			bFoundFID =  true;
			break;
	i = 0;
		i++;
//        OGRGeometry *poGeometry;
		if( poGeometry != NULL && !poGeometry->IsEmpty() )
			poFeatureOut = OGRFeature::CreateFeature( poLayerOut->GetLayerDefn() );
			poFeatureOut->SetFrom(poFeature);
			if (bAssignFID)
				poFeatureOut->SetField( iField, i );
			if( poLayerOut->CreateFeature( poFeatureOut ) != OGRERR_NONE )
				printf( "Failed to create feature.\n" );
				return( 200 );
		}else
			iFiltered++;
	printf("\n-- Info: Filtered %d NULL or Empty polygons from a total of %d polygons.\n", iFiltered,i );
	OGRDataSource::DestroyDataSource( poDSout );
	return(0);
/*                                Main()                                */
int main( int argc, char *argv[] )
    bool bOpAssignFID    = false;
	bool bOpRepairTopo   = false;
	bool bOpCleanPolys   = false;
	bool bOpDelNullPolys = false;
	int i;
	int rc=0;
	const char *pszSrcFilename = NULL;
	const char *pszAdjFilename = NULL;
    const char *pszDstFilename = NULL;
    char *pzsDstFormat = NULL;
    char *pzsDstFormatDefault = "ESRI Shapefile";
/*      Parse arguments.                                                */
    argc = GDALGeneralCmdLineProcessor( argc, &argv, 0 );
    if( argc < 1 )
        return( -argc );
    if( argc == 1 )
        Usage();
    for( i = 1; i < argc; i++ )
        if( EQUAL(argv[i],"-a") )
            bOpAssignFID = true;
        else if( EQUAL(argv[i],"-r") )
            bOpRepairTopo = true;
        else if( EQUAL(argv[i],"-c") )
            bOpCleanPolys = true;
        else if( EQUAL(argv[i],"-d") )
            bOpDelNullPolys = true;
		else if( EQUAL(argv[i],"-o") && i < argc-1 )
            pszAdjFilename = argv[++i];
		else if( EQUAL(argv[i],"-of") && i < argc-1 )
            pzsDstFormat = argv[++i];
        else if( pszSrcFilename == NULL )
            pszSrcFilename = argv[i];
        else if( pszDstFilename == NULL )
            pszDstFilename = argv[i];
        else
            Usage();
        CPLError( CE_Failure, CPLE_AppDefined, "An input file is required." );
        return(1);
	if( pszDstFilename == NULL && bOpDelNullPolys )
        CPLError( CE_Failure, CPLE_AppDefined, "An output file is required when deleting null geometry records." );
        return(1);
	if ( pzsDstFormat == NULL )
		pzsDstFormat = pzsDstFormatDefault;
/*  Do requested Operations:                                            */
	if ( bOpAssignFID || bOpRepairTopo )
		rc = repairPolygons(pszSrcFilename, bOpAssignFID, bOpRepairTopo );
	if ( bOpCleanPolys )
		rc = cleanPolygons(pszSrcFilename, pszAdjFilename);
	if ( bOpDelNullPolys )
		rc = deleteNullPolygons(pszSrcFilename, pszDstFilename, pzsDstFormat);
/*  Exit:                                                               */
	return(0);
