[gdal-dev] Debugging on Windows Using Visual Studio
Martin Chapman chapmanm at pixia.com
Sun Dec 21 00:16:00 EST 2008
Joel,
I debug into gdal source from visual studio all the time.  Here is what I
do:
1. Use nmake to build gdal from the command line with the nmake.opt file set
to build gdal in the debug configuration.
2. Copy the gdalxxx.dll, gdalxxx_i.lib and gdalxxx.pdb to the same directory
as my application exe or dll.
3. Run my application in debug mode with a break point in my code on the
line I want to debug.
4. When the code breaks in my code then I press F11 to step into the gdal
code.
If it doesn't work then something is out of sync between your code and the
gdal files your are linked against.  Most likely your code can't find the
gdal pdb or the files are out of date.  Make sure you do a full rebuild on
both projects so all files are up to date with the debug symbols. Sometimes
I make that mistake and my code won't step into gdal so I do a full rebuild
and then it works.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Joel Odom
Sent: Friday, December 19, 2008 12:36 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Debugging on Windows Using Visual Studio
Problem solved.  For the benefit of the group and the searchable list
archives, I'll describe here what was going on.
My build on Windows, using makegdal80.sln, was generating a gdal15.dll
with symbols and gdal15.pdb file.  For whatever reason, these files
did not contain sufficient information for me to step in to the code
in a debug session.  After poking around for some time, I found that
the OPTFLAGS in nmake.opt were set to the optimized build.  I'm not
sure why I was seeing the debug symbols loading, but changing OPTFLAGS
to generate a gdal.pdb (along with the gdal15.pdb) gave me the debug
information I needed.  (In 1.6.0, the OPTFLAGS is set for debug when
DEBUG is defined, which seems to make more sense.)
On Fri, Dec 19, 2008 at 11:22 AM, Joel Odom <joelodom at gmail.com> wrote:
> More notes on the issue below.
> ---------- Forwarded message ----------
> From: Joel Odom <joelodom at gmail.com>
> Date: Fri, Dec 19, 2008 at 11:21 AM
> To: Frank Warmerdam <warmerdam at pobox.com>
> I'm building from makegdal80.sln.  I'm also starting my debug sessions
> from this same solution.  I'm getting symbols in gdal15.dll and the
> .pdb file, but I still can't set a break point anywhere.  It's like
> the debug symbols don't map correctly to the source code.
> I'm wondering if there is some flag in the makefile options that is
> not being set, so the program debug information is incomplete?  I am
> able to set a break point in my dll that calls gdal, but not anywhere
> in the gdal methods.  Again, this is all in VS 2005.  I'll post an
> answer here if I figure out the problem before I give up, but if
> anyone has any ideas, I'd appreciate it.
> On Fri, Dec 19, 2008 at 11:10 AM, Frank Warmerdam <warmerdam at pobox.com>
wrote:
>> Joel Odom wrote:
>>> Bruce.  I'm trying to debug an app that uses GDAL from unmanaged C++
>>> on Visual Studio 2005.  I've tried for an hour or two to step into
>>> gdal, running debug sessions both from the project file from which I
>>> build gdal and from the app that calls into GDAL, but even when I run
>>> from the gdal solution itself, it still doesn't let me step through
>>> source code, even though the modules window says gdal15.dll is loaded
>>> with symbols from the same location as my .pdb file.
>> Joel,
>> I have generally not had problems with this.  Did you build GDAL using
>> the nmake files or the solution?  I've had good luck debugging the
>> utilities and into GDAL itself with visual studio. I normally run things
>> from the commandline and pop into visual studio when things crash (even
>> triggering crashes at select points).
>> This is usually with visual studio 2003.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
> http://giscoder.blogspot.com/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
