[gdal-dev] Converting coordinate systems(gdalwarp)
Joaquim Luis jluis at ualg.pt
Sat Feb 2 11:48:41 EST 2008
Omkaranathan wrote:
> Hi,
> I am trying to convert a geotiff file from Lat/Long to UTM coordinates
> using gdalwarp.
> The output data produced is gives proper coordinate system info but
> the data is only a black strip.
> This is the command line option I have used .
> gdalwarp -t_srs "+proj=utm +zone=19 +datum=WGS84" input.tif  out.tif
> Am I doing something wrong?
> It'll be great if you can suggest something.
Omkaranathan
Previous reports of this kind of problem have turn out to be due a 3rd
party reader handicap and not a file problem.
What soft are you using to display the out.tif?
J. Luis
